I have recently started doing a pretty large project of which part is making a servo. The servo I'm planning to build is gonna have a lot of mechanical power (around 300 W). The first thing is the motor control. I bought BTS7960 module or rather IBT2 module capable of controlling up to 43 A of current (voltage up to 36V).
The motor I'm prepering to use is motor of class 775, brushed, 20000 RPM, 12-24V.
And have constructed an circuit to try this out, includes Arduino Mega.
The problem i have:
Using the PWM control in IBT2 of power delivered to the motor I wanted to reduce or increase speed. But the issue occurs when duty cycle of input signal gets arround 50%. The motors current increses 3 times. Fun thing is that when I control voltage through power supply current is proportional (I'm skiping high current during acceleration of motor, measurements were made during stable speeds).
Can somebody tell me why this happens and what to do to decrase this effect?
P.S. I tried connecting in parallel a ceramic and electrolytic capacitor (Cc = 1uF, Ce = 470uF). After this, both motor and capacitor heated up even more, and current increased.
this module, while enabled, connect output pin to powerline or short them, dependent on PWM level. maybe you just connected power to output line and motor to input?
Connections are made properely, power to power, motor to output, other way entire driver wouldn't work. I can't disturb the connection of motor which is a result of inside build of driver.
Thank you for a hint. I measured current on power supply, cuz I have this nice monitor of voltage and current (Longwei LW-K3010D). Used a multimeter on motor circuit and current ist proper, arround 1,1A. So the 3,05 A is on power supply. The main thing about this whole overcurrent is that I want to skip possible issues and motor failures due to overheating. This motor will run at 24V with much bigger mechanical load, so it's important.
Also I forgot, strange thing happens, voltage drops 1-2V in this segment of 40-60% of duty cycle.
(current up, voltage down)
EDIT: made some more precise measurements and higher current happens between 15 and 85% duty cycle. Also voltage drops
