Overlay GPS code error, looking forward for another codes.
I’ve got this error when upload the Overlay GPS sketch, someone know what is the problem?
“OverlayGPS\bitmaps.cpp.o:(.progmem.data+0x0): multiple definition of `bitmaps’
bitmaps.cpp.o:(.progmem.data+0x0): first defined here”
link: http://nootropicdesign.com/ve/downloads/OverlayGPS.zip
OverlayGPS
#include <TVout.h>
#include <fontALL.h>
#include <pollserial.h>
#include <TinyGPS.h>
#include "bitmaps.h"
#define W 128
#define H 98
#define HOMELAT 45.0467231448594
#define HOMELNG -93.47460865974426
#define HOMEALT 315
TVout tv;
pollserial pserial;
TinyGPS gps;
unsigned long lastDisplayTime = 0;
PROGMEM prog_int8_t ticks[] = {3,0,1,0,2,0,1,0,2,0,1,0,2,0,1,0,3,0,1,0,2,0,1,0,2,0,1,0,2,0,1,0,3,0,1,0,2,0,1,0,2,0,1,0,2,0,1,0,3,0,1,0,2,0,1,0,2,0,1,0,2,0,1,0};
float theta;
byte x, y;
void setup()  {
  tv.begin(NTSC, W, H);
  tv.set_hbi_hook(pserial.begin(4800));
  initOverlay();
  tv.select_font(font4x6);
  tv.fill(0);
// Initialize ATMega registers for video overlay capability.
// Must be called after tv.begin().
void initOverlay() {
  TCCR1A = 0;
  // Enable timer1.  ICES0 is set to 0 for falling edge detection on input capture pin.
  TCCR1B = _BV(CS10);
  // Enable input capture interrupt
  TIMSK1 |= _BV(ICIE1);
  // Enable external interrupt INT0 on pin 2 with falling edge.
  EIMSK = _BV(INT0);
  EICRA = _BV(ISC11);
// Required to reset the scan line when the vertical sync occurs
ISR(INT0_vect) {
  display.scanLine = 0;
void debug(int n) {
  tv.print(0, 90, n);
int getMemory() {
  int size = 512;
  byte *buf;
  while ((buf = (byte *) malloc(--size)) == NULL);
  free(buf);
  return size;
void displayData() {
  float lat, lng;
  unsigned long fix_age;
  lat = 0.0;
  lng = 0.0;
  gps.f_get_position(&lat, &lng, &fix_age);
  tv.delay_frame(1);
  tv.print(0, 0, lat, 4);
  printRightJustified(W-36, 0, lng, 4);
  displayCourse();
  displaySpeed();
  displayAltitude();
  // display distance from home
  printRightJustified(118, 90, gps.distance_between(HOMELAT, HOMELNG, lat, lng));
  tv.bitmap(122, 89, bitmaps+28, 0, 0, 0);
  // erase home arrow
  byte x1 = 64 + (20 * cos(theta));
  byte x2 = 64 + (25 * cos(theta));
  byte y1 = 50 - (20 * sin(theta));
  byte y2 = 50 - (25 * sin(theta));
  tv.draw_line(x1, y1, x2, y2, 0);
  // compute direction home expressed as radians relative to x axis.  Range [-pi,pi]
  theta = atan2(HOMELAT-lat, HOMELNG-lng);
  tv.draw_line(x1, y1, x2, y2, 1);
  // convert to degrees relative to x axis.  Range [-180,180]
  directionHome = degrees(directionHome);
  // convert to range [0,360]
  if (directionHome < 0) {
    directionHome += 360;
  // convert to degrees clockwise relative to 0 degree heading (north)
  directionHome = 360 - (directionHome - 90);
void displayCourse2() {
  int course = (int)(gps.f_course() + 0.5);
  x = 66;
  y = 18;
  printRightJustified(x, y, course);
void displayCourse() {
  byte index;
  // clear
  for(y=8;y<23;y++) {
    for(x=4;x<12;x++) {
      display.screen[(y*(W/8))+x] = 0;
  x = 66;
  y = 18;
  tv.draw_line(x-4, 5, x-1, 5, 1);
  tv.set_pixel(x-3, 6, 1);
  x = 48;
  y = y-2;
  course -= 90;
  if (course < 0) {
    course += 360;
  index = (byte)(((float)course / 5.625) + 0.5);
  for(byte t=0;t<=32;t++) {
    byte len = pgm_read_byte(ticks+index);
    switch (len) {
    case 3:
      tv.set_pixel(x, y-2, 1);
      tv.bitmap(x-2, y-8, bitmaps+(7*(index/16)), 0, 0, 0);
    case 2:
      tv.set_pixel(x, y-1, 1);
    case 1:
      tv.set_pixel(x, y, 1);
    index++;
    if (index >= 64) {
      index = 0;
    x++;
void displaySpeed() {
  int speed = (int)(gps.f_speed_knots() + 0.5);
  //int speed = analogRead(5);
  byte middle = 50;
  for(y=(middle-22);y<=(middle+22);y++) {
    for(x=0;x<4;x++) {
  x = 17;
  for(int s=(speed+40);s>=(speed-40);s--) {
    y = middle-((s-speed)/2);
    if ((s % 4) == 0) {
    if ((s % 20) == 0) {
      tv.set_pixel(x-1, y, 1);
      if (s > 0) {
	printRightJustified(8, y-2, s);
  y = middle-4;
  x = 12;
  tv.draw_line(0, y-1, x, y-1, 0);
  tv.draw_line(0, y, x, y, 1);
  y++;
  tv.draw_line(0, y, x, y, 0);
  tv.set_pixel(x++, y++, 1);
  printRightJustified(8, y, speed);
  tv.set_pixel(x--, y++, 1);
  tv.set_pixel(x, y++, 1);
  tv.draw_line(0, y+1, x, y+1, 0);
void displayAltitude() {
  int altitude = (int)(gps.f_altitude() + 0.5) - HOMEALT;
  //int altitude = analogRead(5);
  byte middle = 50;
  for(y=middle-22;y<=(middle+22);y++) {
    for(x=((W/8)-4);x<(W/8);x++) {
  x = 108;
  for(int a=(altitude+40);a>=(altitude-40);a--) {
    y = middle-((a-altitude)/2);
    if ((a % 4) == 0) {
    if ((a % 20) == 0) {
      tv.set_pixel(x+1, y, 1);
      printRightJustified(123, y-2, a);
  y = middle-4;
  x = 114;
  tv.draw_line(x, y-1, x+12, y-1, 0);
  tv.draw_line(x, y, x+12, y, 1);
  y++;
  tv.draw_line(x, y, x+12, y, 0);
  x--;
  printRightJustified(x+11, y, altitude);
  tv.draw_line(x, y+1, x+12, y+1, 0);
void printRightJustified(byte x, byte y, int n) {
  if (n < 0) {
    x -= 4;
  int posN = abs(n);
  if (posN >= 10) {
    x -= 4;
  if (posN >= 100) {
    x -= 4;
  if (posN >= 1000) {
    x -= 4;
  tv.print(x, y, n);
void printRightJustified(byte x, byte y, float f, int nDecimal) {
  if (f >= 10) {
    x -= 4;
  if (f >= 100) {
    x -= 4;
  if (f >= 1000) {
    x -= 4;
  tv.print(x, y, f, nDecimal);
  if (readGPS() && ((millis() - lastDisplayTime) > 500)) {
    lastDisplayTime = millis();
    displayData();
    //debug(getMemory());
bool readGPS() {
  char c;
  while (pserial.available()) {
    if (gps.encode(pserial.read())) {
      return true;
  return false;
bitmaps.cpp
PROGMEM prog_uchar bitmaps[] = {
  // N
  5,5,
  0b10001000,
  0b11001000,
  0b10101000,
  0b10011000,
  0b10001000,
  // E
  5,5,
  0b11111000,
  0b10000000,
  0b11111000,
  0b10000000,
  0b11111000,
  // S
  5,5,
  0b01111000,
  0b10000000,
  0b01110000,
  0b00001000,
  0b11110000,
  // W
  5,5,
  0b10001000,
  0b10001000,
  0b10101000,
  0b10101000,
  0b01010000,
  // home
  6,6,
  0b00110000,
  0b01111000,
  0b11111100,
  0b01111000,
  0b01011000,
  0b01011000
bitmaps.h
#ifndef BITMAPS_H
#define BITMAPS_H
#include <avr/pgmspace.h>
extern prog_uchar bitmaps[];
#endif
Are you sure you are using the ENHANCED version of the TVOut library as described here:
