hi, i was running an LED directly from d12 as well as a RC received on a pro mini 5V. Now the VCC is only putting out 2.8V instead of 5V. Have I blownt the voltage reg and d12? Is it repairable? Seems like its also doing some other weird stuff now too.
captaingeek:
My guess is if you would have read the documentation it says NOT to connect a LED directly to the pin but through a resistor. Hmm I smell smoke!
It also possible you damaged the IO pin which is ultimately causing the regulator drag down.
