Hi! Can you please help me with my code? I attach a copy below. I’m still new to Arduino, currently doing a project where the main function is using LDR sensor to control the switching a light bulb. But what i really want is for the virtual button from the Blynk application to be able to override/ignore the main function and control the switching of the light bulb while using the BLYNK app (if light bulb is on, virtual button can turn off and vice versa), and the program will go back to main function when the Blynk app is turned off.
const int ledPin = 13; //the number of the LED pin
const int ldrPin = A0; //the number of the LDR pin
int relay1State = 0;
// Debug console
// Set ESP8266 baud rate
EspSerial.begin(ESP8266_BAUD);
delay(10);
Blynk.begin(auth, wifi, ssid, pass);
pinMode(ledPin, OUTPUT); //initialize the LED pin as an output
pinMode(ldrPin, INPUT); //initialize the LDR pin as an input
BLYNK_WRITE(V1) {
relay1State = param.asInt();
digitalWrite(ledPin, relay1State);
void checkLDR() {
int relay1Status = digitalRead(ledPin);
int ldrStatus = analogRead(ldrPin); //read the status of the LDR value
//check if the LDR status is <= 300
//if it is, the LED is HIGH
if (ldrStatus <=300 ) {
digitalWrite(ledPin, HIGH); //Lights on
Serial.println("Light Bulb is ON");
Blynk.virtualWrite(V1, relay1Status);
else {
digitalWrite(ledPin, LOW); //Lights off
Serial.println("Light Bulb is OFF");
// Update Button Widget
Blynk.run();
checkLDR();
I’m planning on using the attachinterrupt() function but do not fully understand on how to use it for this program.
