Can anyone explain how I would redefine the PCINT1_vect ISR to eliminate the one defined in softwareSerial? I am not a C++ programmer, so I don't understand what was done in SoftwareSerial.cpp .
I need to monitor pin changes on that port, but SoftwareSerial has already defined a function for that purpose and I get an error when compiling.
SoftwareSerial\SoftwareSerial.cpp.o: In function __vector_10': E:\Installers\Arduino\arduino-1.0.1-windows\arduino-1.0.1\libraries\SoftwareSerial/SoftwareSerial.cpp:309: multiple definition of
__vector_10'
ProductSw_X.cpp.o:C:\Users\James\AppData\Local\Temp\build3409413193090911518.tmp/ProductSw_X.cpp:1928: first defined here
My code looks like this and works just fine with older versions of SoftwareSerial.
ISR(PCINT1_vect) {
if(misoInt == 0) {
misoInt = 1;
Can someone re-write my ISR to avoid this conflict?
OR ... wouldn't it be better if SoftwareSerial did not assume that one would never want to use PCINT1_vect for any other purpose?
