Hi all
I am currently working on an RC Car project, which receives commands over serial. I would like to be able to override commands, rather than having them queue up. For example, if the car is driving forward, and I enter the right turn command into the Serial Monitor, I want it to immediately stop running forward and turn right. I'm pretty sure that it shouldn't require too much changing.
RC Car Project Mark II
#include <AFMotor.h>
#include <math.h>
String readString, function, mspeed, duration;
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
const int rightLEDs = 9;
const int leftLEDs = 10;
const int buttonPin = 2;
const int buzzerPin = A0;
const int thermistorPin = A1;
int buttonState = 0;
float vcc = 4.91;
float pad = 9850;
float thermr = 10000;
float Thermistor(int RawADC)
long Resistance;
float Temp;
Resistance = ((1024 * thermr / RawADC) - pad);
Temp = log(Resistance);
Temp = 1 / (0.001129148 + (0.000234125 * Temp) + (0.0000000876741 * Temp * Temp * Temp));
Temp = Temp - 273.15;
Temp = (Temp * 9.0)/ 5.0 + 32.0;
return Temp;
void motorSet(char motor_direction, word motor_speed, int motor_duration)
motor1.setSpeed(motor_speed);
motor2.setSpeed(motor_speed);
motor3.setSpeed(motor_speed);
motor4.setSpeed(motor_speed);
if(motor_direction == 'f')
if(motor_speed < 255)
Serial.print("Running forward at ");
Serial.print(motor_speed);
Serial.print(" / 255 speed for ");
Serial.print(motor_duration / 1000);
Serial.println(" seconds.");
if(motor_speed == 255)
Serial.print("Running forward at full speed for ");
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
if(motor_direction == 'r')
Serial.print("Running backward at ");
Serial.print("Running backward at full speed for ");
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
delay(motor_duration);
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
pinMode(rightLEDs, OUTPUT);
pinMode(leftLEDs, OUTPUT);
pinMode(buttonPin, INPUT);
pinMode(buzzerPin, OUTPUT);
pinMode(thermistorPin, INPUT);
digitalWrite(rightLEDs, HIGH);
digitalWrite(leftLEDs, HIGH);
Serial.println("RC Car Project Mark II connected.");
while (Serial.available())
delay(1);
if (Serial.available() > 0)
char c = Serial.read();
readString += c;
if(readString.length() > 0)
function = readString.substring(0, 1);
mspeed = readString.substring(1, 4);
duration = readString.substring(4, 6);
if(function == 'f') function = "FORWARD";
if(function == 'r') function = "REVERSE";
if(function == 'a') function = "RIGHT_TURN";
if(function == 'b') function = "LEFT_TURN";
if(function == 'h' && mspeed == "onn") function = "HEADLIGHTS_ON";
if(function == 'h' && mspeed == "off") function = "HEADLIGHTS_OFF";
if(function == 'h' && mspeed == "orn") function = "SHORT_HORN";
if(function == 'l' && mspeed == "kho" && duration == "rn") function = "HORN_LOCK_ON";
if(function == 'n' && mspeed == "oho" && duration == "rn") function = "HORN_LOCK_OFF";
if(function == 'c' && mspeed == "tem" && duration == "pf") function = "CURRENT_TEMP";
word newSpeed;
long newDuration;
char carray1[9];
mspeed.toCharArray(carray1, sizeof(carray1));
newSpeed = atoi(carray1);
char carray2[9];
duration.toCharArray(carray2, sizeof(carray2));
newDuration = atoi(carray2);
newDuration = newDuration * 1000;
buttonState = digitalRead(buttonPin);
if(buttonState == LOW)
if(function == "FORWARD")
motorSet('f', newSpeed, newDuration);
if(function == "RIGHT_TURN")
Serial.println("Turning right.");
motor1.setSpeed(100);
motor2.setSpeed(100);
motor3.setSpeed(100);
motor4.setSpeed(100);
delay(1500);
if(function == "LEFT_TURN")
Serial.println("Turning left.");
delay(1500);
if(function == "HEADLIGHTS_OFF")
Serial.println("Headlights off.");
digitalWrite(rightLEDs, LOW);
digitalWrite(leftLEDs, LOW);
if(function == "HEADLIGHTS_ON")
Serial.println("Headlights on.");
if(function == "SHORT_HORN")
Serial.println("Horn sounded.");
analogWrite(buzzerPin, 255);
delay(2000);
analogWrite(buzzerPin, 0);
if(function == "HORN_LOCK_ON")
Serial.println("Horn lock on.");
if(function == "HORN_LOCK_OFF")
Serial.println("Horn lock off.");
if(function == "CURRENT_TEMP")
float temp;
temp = Thermistor(analogRead(thermistorPin));
temp = (temp * 9.0) / 5.0 + 32.0;
Serial.print("The current temperature is ");
Serial.print(temp,1);
Serial.println(" degrees Fahrenheit.");
if(function == "REVERSE")
motorSet('r', newSpeed, newDuration);
if(buttonState == HIGH && function != "REVERSE" && function != "HEADLIGHTS_OFF"
&& function != "HEADLIGHTS_ON" && function != "SHORT_HORN" && function != "HORN_LOCK_ON"
&& function != "HORN_LOCK_OFF" && function != "CURRENT_TEMP")
Serial.println("Obstruction in way. Command canceled.");
readString = "";
readString = "";
Second, I am having trouble setting up a blinking loop which will act as a turn signal while the car turns. I can't seem to get it to loop while the car is turning. It only runs once. Maybe I have to have a while loop?
void turnSignal(char side, boolean state)
boolean newLEDState = !ledState;
if(state == true)
if(side == 'r')
digitalWrite(rightLEDs, newLEDState);
delay(250);
digitalWrite(rightLEDs, ledState);
delay(250);
if(side == 'l')
digitalWrite(leftLEDs, newLEDState);
delay(250);
digitalWrite(leftLEDs, ledState);
delay(250);
if(state == false)
turnSignal('r', true);
delay(1500);
turnSignal('r', false);
turnSignal('l', true);
delay(1500);
turnSignal('l', false);
