ovf with max(x,y) on analogRead
Why do I get an ovf on line 30 (noise=maxCurr;)? Performing 10x (for loop) analogRead(0) and taking the maximum value (maxCurr) gives ovf.
The noise formula actually should be noise=maxCurr-minCurr; but for debugging I disply maxCurr only.
Measuring Current Using ACS712
void setup(){
void loop(){
float current;
float maxCurr;
float minCurr;
int rawcurr;
float noise;
static char disp[7];
for( int i=0; i<10; i++)
rawcurr = analogRead(0);
current = current + (516 - rawcurr) * 30/1023.0;
maxCurr = max(maxCurr, rawcurr);
minCurr = min(minCurr, rawcurr);
delay(50);
current = current / 10.0;
dtostrf(current, 5,3,disp);
//maxCurr = (516 - maxCurr)*30/1023,0;
//minCurr = (516 - minCurr)*30/1023,0;
noise = maxCurr;
 delay(10);
 //Serial.print( current);
 //Serial.print((float)(current),2);
 //Serial.print(" , ");
 Serial.print(disp);
 Serial.print(noise);
 Serial.print(current, 3);
 Serial.println(rawcurr);
Solved: I do not reset the maxCurr and minCurr variables entering the loop so carrying the values from the previous loop back into te for loop. In setup I write now: float maxCurr = 0; float minCurr = 0;
I hope this gets your approval?
New issue: now I always get value 0 for minCurr.
What do I do wrong?
No, it does not. Creating new variables that are local to setup(), and that have the same name as global variables, does not make sense.
Learn when to use a type in front of a variable name, and when not to. THAT would meet with our approval.
What do I do wrong?
You made code changes without posting the code, so you are asking us to guess what you are doing wrong. I don't care much for guessing games, so I'll pass.
What PaulS said. Plus this:
float minCurr = 0;
is not going to work. The analogRead function returns values from 0 to 1023. Therefore min(minCurr,rawcurr) will always return zero. You need to initialize minCurr to a value that is at least as high as the highest value that can occur.
Pete
Hi PaulS and el_supremo, thanks for the feedback; I corrected the code for the min calculation.
Here is the code: please peruse and I appreciate your comments. I am sorry for my previous post, code will always be included in the future.
void setup(){
void loop(){
float current;
float maxCurr = 0;
float minCurr = 516;
int rawcurr;
float noise;
delay(50);
noise = (maxCurr - minCurr)*30/1023.0;
 delay(10);
 Serial.print(disp);
Why are maxCurr and minCurr float, when rawcurr is int? Why is rawcurr not rawCurr?
PaulS:
The true answer is that I do not know, but you are correct: I changed the code to reflect you comments.
How do I make a printout of the serial monitor?
void setup(){
void loop(){
float current;
int maxCurr = 0;
int minCurr = 516;
int rawCurr;
float noise;
rawCurr = analogRead(0);
current = current + (516 - rawCurr) * 30/1023.0;
maxCurr = max(maxCurr, rawCurr);
minCurr = min(minCurr, rawCurr);
delay(50);
 delay(10);
 Serial.print(disp);
 Serial.println(rawCurr);
It shows text. Highlight the text, copy it, and paste it here.
Thanks PaulS; I had to stop the autoscroll to get it to work, but here it is:
This is at 0A current.
current noise current rawCurr
0.164 , 0.34 , 0.164 , 507
0.029 , 0.29 , 0.029 , 513
0.037 , 0.32 , 0.037 , 520
0.082 , 0.69 , 0.082 , 504
0.113 , 0.40 , 0.113 , 511
0.021 , 0.21 , 0.021 , 514
0.124 , 0.32 , 0.124 , 513
0.095 , 0.45 , 0.095 , 510
0.063 , 0.45 , 0.063 , 511
0.074 , 0.48 , 0.074 , 509
Strange that there is a current being “measured”, or rather, calculated.
At 2A:
1.626 , 0.71 , 1.626 , 451
1.555 , 0.42 , 1.555 , 452
1.552 , 0.45 , 1.552 , 466
1.512 , 0.53 , 1.512 , 461
1.504 , 0.32 , 1.504 , 461
1.623 , 0.37 , 1.623 , 454
1.518 , 0.79 , 1.518 , 447
1.631 , 0.58 , 1.631 , 456
So not quite right yet: at 2A it shows about 1.6A calculated.
I did meanwhile write a value 0 in the float current at the start of the loop:
void setup(){
void loop(){
float current = 0;
int maxCurr = 0;
int minCurr = 516;
int rawCurr;
float noise;
current = current + (516 - rawCurr) * 27/1023.0;
delay(50);
noise = (maxCurr - minCurr)*27/1023.0;
 delay(10);
 Serial.print(disp);
Where did the 516 and 27 magic numbers come from? Perhaps they are not right for the sensor you have.
Post a link to the sensor and a schematic.
Have you measured the voltage at the analog input pin, for zero current, then 2A? This will help you to get your offset and gain values for calculation correct.
Tom... :)
PaulS:
The ACS outputs 2.5V (measured 2.490Vdc to 2.510Vdc with Fluke) at 0A, and 0.185mV/A. The Arduino ADC scale is 1023 units for FSD of 5V. And 0A corresponds to 1023/2=512, halfway the ADC scale. 5V / x = 0.185V / 1A.
So x = 5 / 0.185 = 27. Final formula: actual current in A = (512 - ADC value) x 27 / 1023
ADC value = analogRead(0) = rawCurr
In my program I mistaken entered 516 instead of 512: correction below.
At 0A the output shows around 0A, at 2A, the output is around 1.4A:
1.293 , 0.29 , 1.293 , 457
1.383 , 0.66 , 1.383 , 462
1.415 , 0.40 , 1.415 , 463
1.441 , 0.18 , 1.441 , 461
1.372 , 0.69 , 1.372 , 461
1.462 , 0.58 , 1.462 , 458
1.380 , 0.45 , 1.380 , 453
void setup(){
void loop(){
float current = 0;
int maxCurr = 0;
int minCurr = 516;
int rawCurr;
float noise;
current = current + (512 - rawCurr) * 27/1023.0;
delay(50);
 delay(10);
 Serial.print(disp);
When I push 2A, the ACS outputs 2.28V... not quite the 2.5V - 2 x 0.185V/A..
Same result on a spare ACS, and they both are the 05B version thus 0.185V/A.
Hi, When you put 2A through the sensor, with a DMM measure the voltage at the analog input, please. Read post #11.
Have you got the output of the sensor and its supply bypassed with 0.1uF Caps?
Thanks.. Tom... :)
Hi Tom, analog input receives 2.58V @ 0A, 2.28V @2A.
Yes, the sensor output is filtered with a 100nF cap on one unit and a self-installed extra 100nF cap on the other unit.
Hi, Exactly what model ACS712 do you have 5A or 30A?
Can you post a picture of the ACS712 and its connections to the arduino?
Tom..Sorry but I couldn't find any reference to which model.
Tom, both units here are the 5A model.
The circuit is 5V and GND from the Arduino, and the ACS output via breadboard to a 4.7k pulldown (load) resistor. Short wires, 10cm leads.
Picture to follow.
Increase the load R to 10k or try without it, 4k7 is the data sheet MIN.
