Oxygen Concentration calculation
Hi everyone,
I am relatively new to programming and I am working with a heart rate sensor. However, I also wanted to calculate SpO2 using infrared and red light reflections. I have stumbled across the following code and I was wondering if someone could help me.
Some context: https://www.nxp.com/docs/en/application-note/AN4327.pdf
void calcSpO2(uint32_t *pun_ir_buffer, int32_t n_ir_buffer_length, uint32_t *pun_red_buffer, int32_t *pn_spo2, int8_t *pch_spo2_valid)
  uint32_t un_ir_mean,un_only_once ;
  int32_t k, n_i_ratio_count;
  int32_t i, s, m, n_exact_ir_valley_locs_count, n_middle_idx;
  int32_t n_th1, n_npks, n_c_min;
  int32_t an_ir_valley_locs[15] ;
  int32_t n_peak_interval_sum;
  int32_t n_y_ac, n_x_ac;
  int32_t n_spo2_calc;
  int32_t n_y_dc_max, n_x_dc_max;
  int32_t n_y_dc_max_idx, n_x_dc_max_idx;
  int32_t an_ratio[5], n_ratio_average;
  int32_t n_nume, n_denom ;
  // Calculates DC mean and subtract DC from ir
  un_ir_mean =0;
  for (k=0 ; k<n_ir_buffer_length ; k++ ) un_ir_mean += pun_ir_buffer[k] ;
  un_ir_mean =un_ir_mean/n_ir_buffer_length ;
  // Remove DC and invert signal so that we can use peak detector as valley detector
    an_x[k] = -1*(pun_ir_buffer[k] - un_ir_mean) ;
  // 4 pt Moving Average
  for(k=0; k< BUFFER_SIZE-MA4_SIZE; k++){
    an_x[k]=( an_x[k]+an_x[k+1]+ an_x[k+2]+ an_x[k+3])/(int)4;
  // Calculate threshold
  n_th1=0;
  for ( k=0 ; k<BUFFER_SIZE ;k++){
    n_th1 +=  an_x[k];
  n_th1=  n_th1/ ( BUFFER_SIZE);
  if( n_th1<30) n_th1=30; // min allowed
  if( n_th1>60) n_th1=60; // max allowed
  for ( k=0 ; k<15;k++) an_ir_valley_locs[k]=0;
  // Use peak detector as valley detector since we flipped signal
  maxim_find_peaks( an_ir_valley_locs, &n_npks, an_x, BUFFER_SIZE, n_th1, 4, 15 );//peak_height, peak_distance, max_num_peaks
  n_peak_interval_sum =0;
  // Load raw value again for SPO2 calculation : RED(=y) and IR(=X)
  for (k=0 ; k<n_ir_buffer_length ; k++ )  {
      an_x[k] =  pun_ir_buffer[k] ;
      an_y[k] =  pun_red_buffer[k] ;
  // Find precise min near an_ir_valley_locs
  n_exact_ir_valley_locs_count =n_npks;
  // Using exact_ir_valley_locs , find ir-red DC and ir-red AC for SPO2 calibration an_ratio
  // Find AC/DC maximum of raw
  n_ratio_average =0;
  n_i_ratio_count = 0;
  for(k=0; k< 5; k++) an_ratio[k]=0;
  for (k=0; k< n_exact_ir_valley_locs_count; k++){
    if (an_ir_valley_locs[k] > BUFFER_SIZE ){
      *pn_spo2 =  -999 ; // do not use SPO2 since valley loc is out of range
      *pch_spo2_valid  = 0;
      return;
  // Find max between two valley locations
  // and use an_ratio betwen AC compoent of Ir & Red and DC compoent of Ir & Red for SPO2
  for (k=0; k< n_exact_ir_valley_locs_count-1; k++){
    n_y_dc_max= -16777216 ;
    n_x_dc_max= -16777216;
    if (an_ir_valley_locs[k+1]-an_ir_valley_locs[k] >3){
        for (i=an_ir_valley_locs[k]; i< an_ir_valley_locs[k+1]; i++){
          if (an_x[i]> n_x_dc_max) {n_x_dc_max =an_x[i]; n_x_dc_max_idx=i;}
          if (an_y[i]> n_y_dc_max) {n_y_dc_max =an_y[i]; n_y_dc_max_idx=i;}
      n_y_ac= (an_y[an_ir_valley_locs[k+1]] - an_y[an_ir_valley_locs[k] ] )*(n_y_dc_max_idx -an_ir_valley_locs[k]); //red
      n_y_ac=  an_y[an_ir_valley_locs[k]] + n_y_ac/ (an_ir_valley_locs[k+1] - an_ir_valley_locs[k])  ;
      n_y_ac=  an_y[n_y_dc_max_idx] - n_y_ac;    // subracting linear DC compoenents from raw
      n_x_ac= (an_x[an_ir_valley_locs[k+1]] - an_x[an_ir_valley_locs[k] ] )*(n_x_dc_max_idx -an_ir_valley_locs[k]); // ir
      n_x_ac=  an_x[an_ir_valley_locs[k]] + n_x_ac/ (an_ir_valley_locs[k+1] - an_ir_valley_locs[k]);
      n_x_ac=  an_x[n_y_dc_max_idx] - n_x_ac;      // subracting linear DC compoenents from raw
      n_nume=( n_y_ac *n_x_dc_max)>>7 ; //prepare X100 to preserve floating value
      n_denom= ( n_x_ac *n_y_dc_max)>>7;
      if (n_denom>0  && n_i_ratio_count <5 &&  n_nume != 0)
        an_ratio[n_i_ratio_count]= (n_nume*100)/n_denom ; //formular is ( n_y_ac *n_x_dc_max) / ( n_x_ac *n_y_dc_max) ;
        n_i_ratio_count++;
  // Choose median value since PPG signal may varies from beat to beat
  maxim_sort_ascend(an_ratio, n_i_ratio_count);
  n_middle_idx= n_i_ratio_count/2;
  if (n_middle_idx >1)
    n_ratio_average =( an_ratio[n_middle_idx-1] +an_ratio[n_middle_idx])/2; // use median
    n_ratio_average = an_ratio[n_middle_idx ];
  if( n_ratio_average>2 && n_ratio_average <184){
    n_spo2_calc= uch_spo2_table[n_ratio_average] ;
    *pn_spo2 = n_spo2_calc ;
    *pch_spo2_valid  = 1;//  float_SPO2 =  -45.060*n_ratio_average* n_ratio_average/10000 + 30.354 *n_ratio_average/100 + 94.845 ;  // for comparison with table
  else{
    *pn_spo2 =  -999 ; // do not use SPO2 since signal an_ratio is out of range
* \brief        Find peaks
* \par          Details
*               Find at most MAX_NUM peaks above MIN_HEIGHT separated by at least MIN_DISTANCE
* \retval       None
void maxim_find_peaks( int32_t *pn_locs, int32_t *n_npks,  int32_t  *pn_x, int32_t n_size, int32_t n_min_height, int32_t n_min_distance, int32_t n_max_num )
  maxim_peaks_above_min_height( pn_locs, n_npks, pn_x, n_size, n_min_height );
  maxim_remove_close_peaks( pn_locs, n_npks, pn_x, n_min_distance );
  *n_npks = min( *n_npks, n_max_num );
* \brief        Find peaks above n_min_height
* \par          Details
*               Find all peaks above MIN_HEIGHT
* \retval       None
void maxim_peaks_above_min_height( int32_t *pn_locs, int32_t *n_npks,  int32_t  *pn_x, int32_t n_size, int32_t n_min_height )
  int32_t i = 1, n_width;
  *n_npks = 0;
  while (i < n_size-1){
    if (pn_x[i] > n_min_height && pn_x[i] > pn_x[i-1]){      // find left edge of potential peaks
      n_width = 1;
      while (i+n_width < n_size && pn_x[i] == pn_x[i+n_width])  // find flat peaks
        n_width++;
      if (pn_x[i] > pn_x[i+n_width] && (*n_npks) < 15 ){      // find right edge of peaks
        pn_locs[(*n_npks)++] = i;
        // for flat peaks, peak location is left edge
        i += n_width+1;
        i += n_width;
      i++;
* \brief        Remove peaks
* \par          Details
*               Remove peaks separated by less than MIN_DISTANCE
* \retval       None
void maxim_remove_close_peaks(int32_t *pn_locs, int32_t *pn_npks, int32_t *pn_x, int32_t n_min_distance)
  int32_t i, j, n_old_npks, n_dist;
  /* Order peaks from large to small */
  maxim_sort_indices_descend( pn_x, pn_locs, *pn_npks );
  for ( i = -1; i < *pn_npks; i++ ){
    n_old_npks = *pn_npks;
    *pn_npks = i+1;
    for ( j = i+1; j < n_old_npks; j++ ){
      n_dist =  pn_locs[j] - ( i == -1 ? -1 : pn_locs[i] ); // lag-zero peak of autocorr is at index -1
      if ( n_dist > n_min_distance || n_dist < -n_min_distance )
        pn_locs[(*pn_npks)++] = pn_locs[j];
  // Resort indices int32_to ascending order
  maxim_sort_ascend( pn_locs, *pn_npks );
* \brief        Sort array
* \par          Details
*               Sort array in ascending order (insertion sort algorithm)
* \retval       None
void maxim_sort_ascend(int32_t  *pn_x, int32_t n_size)
  int32_t i, j, n_temp;
  for (i = 1; i < n_size; i++) {
    n_temp = pn_x[i];
    for (j = i; j > 0 && n_temp < pn_x[j-1]; j--)
        pn_x[j] = pn_x[j-1];
    pn_x[j] = n_temp;
* \brief        Sort indices
* \par          Details
*               Sort indices according to descending order (insertion sort algorithm)
* \retval       None
void maxim_sort_indices_descend(  int32_t  *pn_x, int32_t *pn_indx, int32_t n_size)
    n_temp = pn_indx[i];
    for (j = i; j > 0 && pn_x[n_temp] > pn_x[pn_indx[j-1]]; j--)
      pn_indx[j] = pn_indx[j-1];
    pn_indx[j] = n_temp;
Help you with what?
Help you... what? Use the function? Doesn't the Application Note tell you how to use the function?
Looks like you fill two buffers with IR and RED readings and pass them to the function. You also pass a pointer to the "unsigned long" that the function puts your SpO2 into and a pointer to a "byte" that it puts the "valid reading" flag into.
Sorry. I was wondering if someone could help me understand what was going on in the code. aka what the function does
Sorry for the confusion.
I have refactored the entire file. It mostly makes sense except lines 142 to 151
* \brief        Calculate Spo2
* \par          Details
*               By detecting  peaks of PPG cycle and corresponding AC/DC of red/infra-red signal, the absorptionRatios for the SPO2 is computed.
*               Since this algorithm is aiming for Arm M0/M3. formaula for SPO2 did not achieve the accuracy due to register overflow.
*               Thus, accurate SPO2 is precalculated and save longo uch_spo2_table[] per each absorptionRatios.
* \param[in]    *infraredBuffer     - IR sensor data buffer
* \param[in]    infraredBufferLen   - IR sensor data buffer length
* \param[in]    *redBuffer          - Red sensor data buffer
* \param[out]   *spO2Value          - Calculated SpO2 value
* \param[out]   *spO2Valid          - 1 if the calculated SpO2 value is valid
void calcSpO2(uint32_t *infraredBuffer, int32_t infraredBufferLen, uint32_t *redBuffer, int32_t *spO2Value, int8_t *spO2Valid)
  int32_t k;
  // Calculates DC mean from infrared values
  uint32_t infraredDCMean = 0;
  for (k = 0; k < infraredBufferLen; k++)
	infraredDCMean += infraredBuffer[k];
  infraredDCMean =infraredDCMean/infraredBufferLen;
	infraredRaw[k] = -1*(infraredBuffer[k] - infraredDCMean) ;
  // Calculate 4 pt Moving Average
  for(k = 0; k < BUFFER_SIZE-MA4_SIZE; k++)
    infraredRaw[k] = (infraredRaw[k] + infraredRaw[k+1] + infraredRaw[k+2] + infraredRaw[k+3])/(int)4;
  // Calculate threshold (the average of all of the averages)
  int32_t threshold = 0;
  for (k = 0; k < BUFFER_SIZE; k++)
    threshold +=  infraredRaw[k];
  threshold = threshold/(BUFFER_SIZE);
  // Limit the threshold
  if(threshold < 30)
	threshold = 30; // minimum threshold allowed
  else if(threshold > 60)
	threshold = 60; // max threshold allowed
  // Ensure infrared location buffer is cleared
  int32_t infraredValleyLocations[15];
  for (k = 0; k < 15; k++)
	infraredValleyLocations[k] = 0;
  int32_t numValleys;
  findPeaks(infraredValleyLocations, &numValleys, infraredRaw, BUFFER_SIZE, threshold, 4, 15 );
	infraredRaw[k] =  infraredBuffer[k];
	redRaw[k] =  redBuffer[k];
  // Calculate absorptoin ratios
    int32_t absorptionRatios[5];
  int32_t absorptionRatioCount = 0;
  int32_t redAC, infraredAC;
  int32_t absorptionNume, absorptionDenom;
  // Clear ratio buffer
  for(k = 0; k < 5; k++)
	absorptionRatios[k]=0;
  // Check if any valley locations are out of range
  for (k = 0; k < numValleys; k++)
    if (infraredValleyLocations[k] > BUFFER_SIZE)
      *spO2Value =  -999;
      *spO2Valid  = 0;
      return;
  // Find max between two valley locations and use absorptionRatios betwen AC compoent of Ir & Red and DC compoent of Ir & Red for SPO2
  int32_t redDCMax = -16777216;
  int32_t infraredDCMax = -16777216;
  int32_t redDCMaxIndex, infraredDCMaxIndex;
  for (k = 0; k < numValleys-1; k++)
	// Check if maximums are too close
    if (infraredValleyLocations[k+1] - infraredValleyLocations[k] > 3)
	  // Update maximums if points exist between the two adjacent maximums
      for (int32_t i = infraredValleyLocations[k]; i < infraredValleyLocations[k+1]; i++)
		if (infraredRaw[i] > infraredDCMax) {
		  infraredDCMax = infraredRaw[i];
		  infraredDCMaxIndex = i;
		if (redRaw[i] > redDCMax)
		  redDCMax = redRaw[i];
		  redDCMaxIndex = i;
	  // Calculate AC component for red
      redAC = (redRaw[infraredValleyLocations[k+1]] - redRaw[infraredValleyLocations[k]])*(redDCMaxIndex - infraredValleyLocations[k]);
      redAC = redRaw[infraredValleyLocations[k]] + redAC/(infraredValleyLocations[k+1] - infraredValleyLocations[k]);
      redAC = redRaw[redDCMaxIndex] - redAC;    // subracting linear DC compoenents from raw
	  // Calculate AC component for infrared
	  infraredAC = (infraredRaw[infraredValleyLocations[k+1]] - infraredRaw[infraredValleyLocations[k]])*(infraredDCMaxIndex - infraredValleyLocations[k]);
      infraredAC = infraredRaw[infraredValleyLocations[k]] + infraredAC / (infraredValleyLocations[k+1] - infraredValleyLocations[k]);
      infraredAC = infraredRaw[redDCMaxIndex] - infraredAC;      // subracting linear DC compoenents from raw
	  // Calculate absorption ratio
	  absorptionNume = (redAC*infraredDCMax) >> 7;
      absorptionDenom = (infraredAC*redDCMax) >> 7;
      if (absorptionDenom > 0  && absorptionRatioCount < 5 && absorptionNume != 0)
        absorptionRatios[absorptionRatioCount]= (absorptionNume*100)/absorptionDenom;
        absorptionRatioCount++;
  // Choose median value since PPG signal varies from beat to beat
  int32_t ratioAverage;
  sortAscend(absorptionRatios, absorptionRatioCount);
  int32_t middleIndex = absorptionRatioCount/2;
  // Determine the average ratio
  if (middleIndex > 1)
	// Calculate median
	ratioAverage = (absorptionRatios[middleIndex-1] + absorptionRatios[middleIndex])/2;
	ratioAverage = absorptionRatios[middleIndex];
  if(ratioAverage > 2 && ratioAverage < 184)
	// Valid SpO2 found - use look up table
    *spO2Value = uch_spo2_table[ratioAverage] ;
    *spO2Valid  = 1;
	// SpO2 is out of range
    *spO2Value = -999 ;
    *spO2Valid = 0;
	Find at most maxNumPeaks peaks above minHeight separated by at least minDistance
void findPeaks(int32_t *locationIndices, int32_t *numValleys, int32_t *inputData, int32_t size, int32_t minHeight, int32_t minDistance, int32_t maxNumPeaks)
  findPeaksAboveHeight(locationIndices, numValleys, inputData, size, minHeight);
  removeClosePeaks(locationIndices, numValleys, inputData, minDistance);
  *numValleys = min(*numValleys, maxNumPeaks);
	Find all peaks above a minimum height
void findPeaksAboveHeight(int32_t *locationIndices, int32_t *numValleys, int32_t *inputData, int32_t size, int32_t minHeight)
  int32_t i = 1, width;
  *numValleys = 0;
  while (i < size-1)
	// Find left edge of potential peaks
    if (inputData[i] > minHeight && inputData[i] > inputData[i-1])
      width = 1;
	  // If peak is flat
      while (i + width < size && inputData[i] == inputData[i+width])
		width++;
	  // Find right edge of potential peaks
      if (inputData[i] > inputData[i+width] && (*numValleys) < 15 )
        locationIndices[(*numValleys)++] = i;
        // Note: For flat peaks, peak location is left edge
        i += width+1;
		i += width;
      i++;
	Remove peaks separated by less than a minimum value
void removeClosePeaks(int32_t *locationIndices, int32_t *numPeaks, int32_t *inputData, int32_t minDistance)
  int32_t prevNumPeaks, dist;
  // Order peaks in descending order
  sortDescend(inputData, locationIndices, *numPeaks);
  // Loop through all peaks
  for (int32_t i = -1; i < *numPeaks; i++ )
    prevNumPeaks = *numPeaks;
    *numPeaks = i + 1;
    for (int32_t j = i + 1; j < prevNumPeaks; j++ )
      dist = locationIndices[j] - (i == -1 ? -1 : locationIndices[i]); // lag-zero peak of autocorr is at index -1
      if ( dist > minDistance || dist < -minDistance )
		locationIndices[(*numPeaks)++] = locationIndices[j];
  // Resort indices to ascending order
  sortAscend(locationIndices, *numPeaks);
void sortAscend(int32_t *inputData, int32_t size)
  int32_t temp;
  for (int32_t i = 1; i < size; i++)
    temp = inputData[i];
    for (int32_t j = i; j > 0 && temp < inputData[j-1]; j--)
		inputData[j] = inputData[j-1];
    inputData[j] = temp;
	Sort indices in descending order (insertion sort algorithm)
void sortDescend(int32_t *inputData, int32_t *pn_indx, int32_t size)
  int32_t temp;
    temp = pn_indx[i];
    for (int32_t j = i; j > 0 && inputData[temp] > inputData[pn_indx[j-1]]; j--)
    pn_indx[j] = temp;
Hi everyone,
I have a question regarding three lines of code I obtained from an API. The goal here is to calciulate SpO2 - blood oxygen concentration but I cannot understand the following lines:
It has something to do with extracting the AC component of the signal as we need this for SpO2. Potentially calculating a deviation of the RMS??
I am not too sure and I would apreciate the help!
Full code:
  int32_t k;
  // Note: we use a valley detecter as an infrared valley represents a heart beat
  // HbO2 absorbs infrared. Increase in Hb02 (heart beat) is decrease in infrared reflection
  // Calculate 4 pt Moving Average - smoothes out the curve
  if(threshold < 30)
  int32_t numValleys;
      *spO2Value =  -999;
      *spO2Valid  = 0;
      return;
  // Find max between two valley locations and use absorption ratios betwen AC compoent of Ir & Red and DC compoent of Ir & Red for SPO2
  redDCMaxIndex = i;
      infraredAC = infraredRaw[infraredValleyLocations[k]] + infraredAC/(infraredValleyLocations[k+1] - infraredValleyLocations[k]);
 // Calculate median
    *spO2Valid  = 1;
    *spO2Value = -999 ;
    *spO2Valid = 0;
  *numValleys = 0;
  while (i < size-1)
      width = 1;
  // If peak is flat
 width++;
        i += width+1;
 i += width;
      i++;
    *numPeaks = i + 1;
  int32_t temp;
  int32_t temp;
    temp = pn_indx[i];
    pn_indx[j] = temp;
  // Calculate median
The "median" is the value in the middle of a sorted list. Half of the values are higher and half of the value are lower.
One part that doesn't make sense is " if (middleIndex > 1)". The middleIndex is the median if the number of samples is odd but if the number of samples is even they take the two middle samples and average them. I think they meant to write " if (absorptionRatioCount & 1)" and reverse the two clauses:
  int32_t ratioMedian;
  int32_t middleIndex = absorptionRatioCount / 2;
  // Determine the median ratio
  if (absorptionRatioCount & 1)  // 1 (true) if odd, 0 (false) if even
    // Odd count, pick the middle sample.
    // Example: For a 9-element list, use index 4 (0-3 below, 5-8 above)
    ratioMedian = absorptionRatios[middleIndex];
    // Even count, average the two middle samples
    // Example: For a 10-element list, average index 4 and 5 (0-4 below, 5-9 above)
    ratioMedian = (absorptionRatios[middleIndex - 1] + absorptionRatios[middleIndex]) / 2;
  if (ratioMedian > 2 && ratioMedian < 184)
    *spO2Value = uch_spo2_table[ratioMedian] ;
    *spO2Valid  = 1;
I am sorry for being unclear johnwasser. My lines must have not lined up.
I do not understand the following lines which pertain to calculating the AC component of the signal:
@ddesousa, do not cross-post. Threads merged.
This is at least the second time we've been down this road so... You should consider your selfish behaviour during your timeout.
Sometimes. when a complex set of expressions are hard to understand, it is good to unroll some of the expressions into smaller expressions:
currentValleyTimeStep = infraredValleyLocations[k];
nextValleyTimeStep =  infraredValleyLocations[k+1];
currentValleyHeight = redRaw[currentValleyTimeStep];
nextValleyHeight =  redRaw[nextValleyTimeStep];
//  How much higher is the next valley [k+1] than the current valley [k]
heightDifferenceToNextValley = nextValleyHeight - currentValleyHeight;
// How many time steps between the next valley [k+1] than the current valley [k]
distanceToNextValley = nextValleyTimeStep - currentValleyTimeStep;
//  How many time steps from the current valley to the peak between valleys
distanceToNextPeak = redDCMaxIndex - currentValleyTimeStep;
// Linear interpolation of the height change for the time step of the peak
expectedChangeInValleyHeightAtPeak  = (heightDifferenceToNextValley * distanceToNextPeak) / distanceToNextValley;
//  Add that to the valley height to get the expected valley height for the time step of the peak
expectedValleyHeightAtPeak = currentValleyHeight + expectedChangeInValleyHeightAtPeak;
// AC component for the peak is the difference between the peak height and the expected valley height
redAC = redRaw[redDCMaxIndex] - expectedValleyHeightAtPeak;
Thank you!
