P10 DMD clock no readable display after upgrading it according to DMD2 library
i have make a clock using one P10 display , but i made this clock using DMD library, which is not supported brightness control, later i found DMD2 which is supported brightness control, but now i cannot modify my code as DMD2 use different parameters, i am not expert in coding , can anybody help me? this is my original code using DMD library.
#include <Wire.h>
#include "RTClib.h"
#include <SPI.h>
#include <DMD.h>
#include <TimerOne.h>
//#include "Arial_black_16.h"
#include "Font.h"
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
RTC_DS1307 rtc;
int h, m, s;
int buttonSetPin = 2; // Pin to enter time setting mode
int buttonHourPin = 3; // Pin to increment hour
int buttonMinutePin = 4; // Pin to increment minute
bool settingMode = false; // Track if in setting mode
  Wire.begin();
  // Initialize RTC
  if (!rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (!rtc.isrunning()) {
    Serial.println("RTC is NOT running! Setting the time.");
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); // Set to compile time
  // Pin setup
  pinMode(buttonSetPin, INPUT_PULLUP);
  pinMode(buttonHourPin, INPUT_PULLUP);
  pinMode(buttonMinutePin, INPUT_PULLUP);
  Timer1.initialize(1000);
  Timer1.attachInterrupt(ScanDMD);
  dmd.clearScreen(true);
int lastHour = -1, lastMinute = -1, lastSecond = -1;
bool colonState = false;  // To track colon blinking state
  // Check button for setting mode
  if (digitalRead(buttonSetPin) == LOW) {
    delay(200); // Debounce delay
    settingMode = !settingMode; // Toggle setting mode
    if (settingMode) {
      Serial.println("Entering time setting mode");
      DateTime now = rtc.now(); // Get current time
      h = now.hour(); // Use current hour for setting
      m = now.minute(); // Use current minute for setting
      Serial.println("Exiting time setting mode");
      rtc.adjust(DateTime(rtc.now().year(), rtc.now().month(), rtc.now().day(), h, m, 0)); // Save time in 24-hour format
      dmd.clearScreen(true); // Clear the screen when exiting time-setting mode
  // Time setting mode (24-hour format)
  if (settingMode) {
    // Increment hour
    if (digitalRead(buttonHourPin) == LOW) {
      h = (h + 1) % 24; // Properly wrap hour to stay between 0 and 23
      Serial.print("Hour set to: ");
      Serial.println(h);  // This will print the 24-hour format during setting mode
    // Increment minute
    if (digitalRead(buttonMinutePin) == LOW) {
      m = (m + 1) % 60; // Properly wrap minutes from 59 to 0
      Serial.print("Minute set to: ");
      Serial.println(m);
    // Show the current time being set on the display in 24-hour format
    displayTime(h, m, s, true); // Passing `true` to indicate time-setting mode
    // Display mode (convert 24-hour to 12-hour format for display)
    h = now.hour(); // Keep `h` in 24-hour format internally
    m = now.minute();
    s = now.second();
    // Only update the display if the time has changed
    if (h != lastHour || m != lastMinute || s != lastSecond) {
      displayTime(h, m, s, false); // Passing `false` for normal display mode
      lastHour = h;
      lastMinute = m;
      lastSecond = s;
    // Handle colon blinking separately without clearing the display
    updateColon(s);
// Function to display time on the DMD
void displayTime(int h, int m, int s, bool isSettingMode) {
  dmd.selectFont(Font);
  // Create buffers for hours and minutes
  char hourBuffer[3];
  char minuteBuffer[3];
  int displayHour = h;
  // If not in time-setting mode, convert 24-hour to 12-hour format for display
  if (!isSettingMode) {
    displayHour = h % 12;  // Convert 24-hour to 12-hour format
    if (displayHour == 0) {
      displayHour = 12;  // Handle midnight/noon cases
  // Format the hour for display
  if (isSettingMode) {
    // Always show hour in 24-hour format in time-setting mode
    snprintf(hourBuffer, sizeof(hourBuffer), "%02d", h); // Keep leading zero for time setting
    // Remove leading zeros for single-digit hours in 12-hour format
    if (displayHour < 10) {
      snprintf(hourBuffer, sizeof(hourBuffer), "%d", displayHour); // No leading zero for single-digit hours
      snprintf(hourBuffer, sizeof(hourBuffer), "%02d", displayHour); // Keep leading zero for double digits
  // Format the minute with leading zeros
  snprintf(minuteBuffer, sizeof(minuteBuffer), "%02d", m);
  // Adjust the position of the hour based on whether it's single or double digits
  int hourPosition = (!isSettingMode && displayHour < 10) ? 7 : 0; // Adjust position only if in display mode and hour is single digit
  // Update only the hour if it has changed
  if (displayHour != lastHour) {
    dmd.drawString(hourPosition, 0, hourBuffer, 2, GRAPHICS_NORMAL); // Display hour
  // Update only the minute if it has changed
  if (m != lastMinute) {
    dmd.drawString(19, 0, minuteBuffer, 2, GRAPHICS_NORMAL); // Display minute
// Function to handle colon blinking without clearing the screen
void updateColon(int s) {
  // Blink colon every second
  if (s % 2 == 0 && !colonState) {
    colonState = true;
    dmd.drawFilledBox(15, 3, 16, 4, GRAPHICS_OR);  // Draw top part of colon
    dmd.drawFilledBox(15, 11, 16, 12, GRAPHICS_OR); // Draw bottom part of colon
  } else if (s % 2 != 0 && colonState) {
    colonState = false;
    dmd.drawFilledBox(15, 3, 16, 4, GRAPHICS_NOR);  // Clear top part of colon
    dmd.drawFilledBox(15, 11, 16, 12, GRAPHICS_NOR); // Clear bottom part of colon
void ScanDMD() {
  dmd.scanDisplayBySPI();
and my modified code which use DMD2 but not able to see stable display and not readable of hour digit, minute can be readable but contains flickering. here is the modified code.
#include <Wire.h>
#include "RTClib.h"
#include <SPI.h>
#include <DMD2.h>
#include "Font.h"
SoftDMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);  // Use SoftDMD for DMD2
RTC_DS1307 rtc;
int h, m, s;
int brightness = 50; // Brightness level (0-255)
  Wire.begin();
  // Initialize RTC
  if (!rtc.begin()) {
    while (1);
  // Pin setup
  // Initialize DMD
  dmd.begin();
  dmd.setBrightness(brightness); // Set initial brightness
  dmd.selectFont(Font); // Set font (can change to preferred font)
  dmd.clearScreen(); // Clear the screen initially
    if (settingMode) {
      dmd.clearScreen(); // Clear the screen when exiting time-setting mode
  if (settingMode) {
    // Increment hour
    // Increment minute
      Serial.println(m);
    displayTime(h, m, s, true); // Passing true to indicate time-setting mode
    h = now.hour(); // Keep h in 24-hour format internally
    m = now.minute();
    s = now.second();
      displayTime(h, m, s, false); // Passing false for normal display mode
      lastHour = h;
      lastMinute = m;
      lastSecond = s;
    updateColon(s);
// Function to display time on the DMD2
  dmd.selectFont(Font); // Select the font
  char hourBuffer[3];
  // Clear the display before updating
  dmd.clearScreen();
  // Display hour and minute
  dmd.drawString(0, 0, hourBuffer,   GRAPHICS_ON);   // Position hour
  dmd.drawString(19, 0, minuteBuffer,   GRAPHICS_ON); // Position minute
    colonState = true;
    dmd.drawFilledBox(15, 3, 16, 4, GRAPHICS_ON);  // Draw top part of colon
    dmd.drawFilledBox(15, 11, 16, 12, GRAPHICS_ON); // Draw bottom part of colon
    colonState = false;
    dmd.drawFilledBox(15, 3, 16, 4, GRAPHICS_OFF);  // Clear top part of colon
    dmd.drawFilledBox(15, 11, 16, 12, GRAPHICS_OFF); // Clear bottom part of colon
void ScanDMD() {
  dmd.scanDisplay();
What is your board?
Arduino uno
