P10 panel rs485 connection
0x2 0x31 0x33 0x31 0x35 0x30 and ending with 0xa I want to send serial 1
0x2 0x31 0x33 0x31 0x35 0x31 and ending with 0xa I want to send serial 2
You could try the following :
const char START_CHAR = '\x02';
const char END_CHAR = '\x0A';
const int BUF_SIZE = 32;
char message[BUF_SIZE];
void receive_message(HardwareSerial &serial)
  int rx_index = 0;
  char rx_char = '\0';
  while (rx_char != START_CHAR)
    while (!serial.available()) {}
    rx_char = serial.read();
  // skip STX
  // read until END_CHAR
  while (rx_char != END_CHAR)
    if (rx_char != END_CHAR)
      if (rx_index < BUF_SIZE - 1)
        message[rx_index] = rx_char;
        rx_index++;
  message[rx_index] = '\0';
void send_message(HardwareSerial &tx_serial)
  tx_serial.write (START_CHAR);
  for (int index = 0; index < strlen(message); index++)
    tx_serial.write (message[index]);
  tx_serial.write (END_CHAR);
  Serial1.begin(9600);
  Serial2.begin(9600);
  receive_message(Serial);
  if (strncmp(message, "13150", 5) == 0)
    send_message(Serial1);
  else if (strncmp(message, "13151", 5) == 0)
    send_message(Serial2);
  // initialize both serial ports:
  // read from port 1, send to port 0:
  if (Serial1.available()) {
    int inByte = Serial1.read();
    Serial.write(inByte);
I could not receive the data coming in this way from the slave 1 Arduino. Is the code correct?
The master receives data from the PC, and send data to the slaves.
Slave 1 receives data for slave 1
Slave 2 receives data for slave 2
I don't see where the slaves send data to the master.
Btw: your pictures are too low res to be useful. All I can see is that there are 3 Megas and a bunch of wires.
slave 1 and slave 2 will only send to the LED screen of the receiving school
The code for the slaves is to call receive_message(), using whatever is the right Serial port.
Then display the received data.
There are examples right in the IDE.
Click on File, then Examples, then Communications.
There is a Multiserial example and a Passthrough example.
if (strncmp(message, "1", 1) == 0)
How can I send only the message without printing these 11 in your code. the code worked fine, thank you
Just change send_message() to start at the third character :
  for (int index = 2; index < strlen(message); index++) // skip the first 2 characters
Why does Slave 2 leave spaces in teacher names? It's as if the line is skipping.
slave 1 and slave 2 have the same code loaded
  int rx_index = 0;
  // skip STX
        rx_index++;
  else if (strncmp(message, "2", 1) == 0)
This is the code you sent master. I changed the final version a little bit.
Turning it off and on again fixed it.
