p10 panel usage
I will do p10 panel control with arduino due, but should I use a different library that gives an error?
error :> DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
C:\Users\LNV\Documents\Arduino\uno_panel\uno_panel.ino: In function 'void ScanDMD()':
uno_panel:18: error: 'dmd' was not declared in this scope
dmd.scanDisplayBySPI();
error.ino (855 Bytes)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What is a p10 panel, links to data/specs would be appreciated.
Where did you get the library and is it written for the DUE?
Have you looked and tried the Examples with the DMD library.
Tom... :slight_smile:
thanks tom ,
no, I wrote the program for the UNO that was not written for DUE, I added the DUE libraries
Have you tried the Examples?
