Hi Guys,
I am new to this esp8266 and need some help to run a quick test if this module is of use to me.
The esp8266 I am using is from digikey partnumber 1568-1235-ND (most common module)
What I like to test is:
One esp6288 with push button on the gpio2
Second esp8266 with external led on gpio2
both powered by ftdi-board and usb cable to the pc
Direct communication between these two esp8266 by wifi (without using Arduino, raspberry or so)
when the pushbutton is pushed, the led on the other esp8266 should light up
(if possible also output (print) to PC-screen by the ftdi connection)
Is any one aware of these codes and willing to supply me the code 'server' and 'client' unit? I like to program the modules using the Arduino IDE
It would be a great help. Many thanks in advance
Frans
The Netherlands
