P2P long range communication - RFM95
I would like to ask you regarding P2P LoRa modul - RFM95 or some other. I need to create P2P communication between far points (in first case about 400 meters in urban area, NRF24l01+ was not sufficient as there are trees and buildings between these points; in second case about 10 km far in unoccupied area). So I was thinking to do it with RFM95 module and arduino. I see there is many modules on the ebay. Would you have any advice which one to select? It need to operate in EU so 868 MHz. + What library then to use. I plan to use it with 2AA batteries.
Thank you in advance for your help.
An nRF24L01+ can't get beyond 10m in practice, its sharing the same frequencies as WiFi and microwave ovens.
I note Adafruit have LoRa RFM95 modules and tutorial: Overview | Adafruit RFM69HCW and RFM9X LoRa Packet Radio Breakouts | Adafruit Learning System
boylucky:
In the EU, its region 1, so you can use 434Mhz which will go twice as far as 868Mhz at the same power.
2 x AA Lithiums OK, 2 x AA Alkalines bad, they will be at 1.2Veachor so for a lot of their life, 2.4V supply is marginal.
@ MarkT - from what I tested the NRF24l01+ can definitely get farther then 10 m. With the PA and LNA can get much more. I succeed with it about 400 meters. The state it should be up to 1000m. The LoRA RFM it is much more better. Thanks for this tip. In the end I will try LoRa Ra-01, which I already ordered. I will see what distance will be reached:
@ Smet - ok, I will also do tests with NiMh which I hope should be also sufficient.
Thanks guys for your advices.
