P5.serialcontrol connected to p5js - problem with port detection
Hi guys!
I tried to connect my Arduino with p5js via p5.serialcontrol. It works but the problem is that it consistently disconnects with the port or rather it doesn't recognize it anymore. This happens while I run my p5js sketch and after I close it and try to open it again.
After some I even have an internal java error for the p5.serialcontrol program.
I am using the arduino groove and was playing an audio file via p5js.
Does anyone have any idea what could be the problem?
Thank you!
Which operating system do you use and can you see anything in the system log files?
I am using windows.
That's the error I got:
I have also tried the same setup on my laptop and its working. My guess is that my usb-port is somehow not working right.
This could be the same issue you have.
Well I can't change the program since I can't access the files.
@ph5
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
I didn't duplicate any question. Here I was asking for a problem that occurred and my new topic was about other options to connect p5js and arduino. How is this the same? That's two completely different questions.
They are on the same subject, information and replies about one might be relevant to the other, added context is generally helpful. Please add your other question here.
Thank you.
That doesn't makes any sense but alright.
WHAT OTHER OPTIONS ARE THERE TO CONNECT ARDUINO WITH P5JS?
