PA6H/MT3339 GPS: how to know if time is GPS locked or from internal RTC?
Image embedded for our convenience:
Technique described here.
In the picture attached you can see the signal on the oscilloscope at power on...
In the signal from GPS, I read in the oscilloscope:
$GPGSV,3,2,10,20,41,.....
Excellent! I'm so glad you can scope this out. This confirms that :
  • The sketch is sending the PMTK configuration command to turn on the GSV sentences.
  • The GPS device receives it correctly on the GPS RX pin.
  • The GPS device is sending GSV sentences.
  • The GPS device can see 10 satellites (3rd field in the GSV sentence).
This eliminates the most common problems. Next:
Now I'm reading:
3 dtsat:4/0
3 dtsat:4/0
near the window.
This shows:
  • the status (3, a good fix),
  • date/time are valid (from RMC and GGA sentences),
  • 4 satellites were used to calculate the current fix (according to the GGA sentence), and
  • 0 satellites were tracked in the gps.satellites[] array.
The first 3 are good. The last one, 0 satellites in the array, is bad.
Since you know the GPS device is sending the GSV sentences, either:
  • the 328 is not receiving anything from the GPS device, or
  • the 328 is receiving GPS characters, but it is not parsing the GSV sentences correctly.
It must be the latter. Are you sure that this line is uncommented?
#define NMEAGPS_PARSE_GSV
NeoGPS will ignore $GPGSV sentences unless this #define is uncommented.
Make sure there are no NeoGPS files in your sketch directory. Having a NeoGPS config file in the sketch directory can make bad things happen. You must modify the config files in the Libraries/NeoGPS/src directory.
Cheers,
/dev
NO! I had uncommented two other lines, but not that!
Now I read:
RTC dtsat:1/2
GPS dtsat:1/2
:slight_smile:
The last version:
It's late, it's 1.20am... I go to sleep!
Now I read:
RTC dtsat:1/2
GPS dtsat:1/2
Very nice! I'm glad it's working.
What's next? :wink:
Hi, /dev :slight_smile:
It works. I only have to understand how variables work.
Now I read:
N/F 0 sats (NoFix)
t 0 sats (only time)
N/F 1 sat (1 sat, but appears again NoFix)
F 5 sats
else if (fix.status == gps_fix::STATUS_NONE) lcd.write(byte(0));
makes appear NF symbol when are received 1 or more sats before fix...
Ok. I've found a solution for the loop():
if (fix.status==gps.fix::STATUS_NONE && fix.satellites==0) lcd.write (byte(0));
0 NF
0 t
1 t
2 t
3 t
4 t
4 F
5 F
Now, only when are 0 satellites can appear the symbol "NF". It works, but why STATUS_NONE is true with one or more satellites?
It still doesn't work in Ora e data.
It seems all is working now! :slight_smile:
I've had to change the structure in OraeData(). Do you agree?
GitHub - Gatware/Limiti at Limiti_3.1_190418_NEO_OK_t all
This means that the MTK device is using that many satellites to calculate a fix (loc, alt, speed, etc.), but the STATUS_NONE means that it has not successfully calculated a fix yet. I see the same thing with a ublox GPS device. The satellites number goes up just before status becomes STATUS_STD.
The GSV satellites number goes up long before that, which sets the status to STATUS_TIME_ONLY.
Your interpretation of fix.valid.time, fix.satellites and fix.status is acceptable. We don't really know what the MTK is "thinking", but your choices seem reasonable. I think this code is equivalent:
    if(fix.valid.status)
      if(fix.status >= gps_fix::STATUS_STD) lcd.print('F'); // Se ha fatto il punto scrive F
      else if((fix.status==gps_fix::STATUS_NONE) && (fix.satellites==0)) lcd.write(byte(0));
      else lcd.print('t');
    else lcd.print('?');
Thank you for your help, /dev.
God bless you!
Cheers,
Gianluca
