paar sketchen van het net.
// Author:Frankie.Chu
// Date:9 April,2012
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
// Modified record:
#include <TimerOne.h>
#include "TM1637.h"
#define ON 1
#define OFF 0
int8_t TimeDisp[] = {0x00,0x00,0x00,0x00};
unsigned char ClockPoint = 1;
unsigned char Update;
unsigned char halfsecond = 0;
unsigned char second;
unsigned char minute = 6;
unsigned char hour = 21;
#define CLK 2//pins definitions for TM1637 and can be changed to other ports
#define DIO 3
TM1637 tm1637(CLK,DIO);
tm1637.set();
tm1637.init();
Timer1.initialize(500000);//timing for 500ms
Timer1.attachInterrupt(TimingISR);//declare the interrupt serve routine:TimingISR
if(Update == ON)
TimeUpdate();
tm1637.display(TimeDisp);
void TimingISR()
halfsecond ++;
Update = ON;
if(halfsecond == 2){
second ++;
if(second == 60)
minute ++;
if(minute == 60)
hour ++;
if(hour == 24)hour = 0;
minute = 0;
second = 0;
halfsecond = 0;
// Serial.println(second);
ClockPoint = (~ClockPoint) & 0x01;
void TimeUpdate(void)
if(ClockPoint)tm1637.point(POINT_ON);
else tm1637.point(POINT_OFF);
TimeDisp[0] = hour / 10;
TimeDisp[1] = hour % 10;
TimeDisp[2] = minute / 10;
TimeDisp[3] = minute % 10;
Update = OFF;
// Author: RSP @ Embedded System Lab (ESL), KMUTNB, Thailand
// Date: 29-Apr-2014
// Target Board: Arduino Uno (ATmega328P, 5V, 16MHz)
// Arduino IDE: version 1.0.5
// Description:
// This Arduino Sketch shows how to interface the Arduino Uno
// to a four-digit 7-segment display that utilizes the TM1637
// LED driver chip.
#define CLK_PIN (2)
#define DIO_PIN (3)
#define bit_delay() asm("nop\n nop\n nop\n nop\n")
#define TM1637_CMD1 (0x40)
#define TM1637_CMD2 (0xC0)
#define TM1637_CMD3 (0x80)
const uint8_t SEVEN_SEG_DIGITS[] = {
// gfedcba
0b00111111, // 0
0b00000110, // 1
0b01011011, // 2
0b01001111, // 3
0b01100110, // 4
0b01101101, // 5
0b01111101, // 6
0b00000111, // 7
0b01111111, // 8
0b01101111, // 9
void tm1637_init() {
pinMode( CLK_PIN, OUTPUT );
pinMode( DIO_PIN, OUTPUT );
digitalWrite( CLK_PIN, HIGH );
digitalWrite( DIO_PIN, HIGH );
void tm1637_start_bit() {
digitalWrite( DIO_PIN, LOW ); bit_delay();
digitalWrite( CLK_PIN, LOW ); bit_delay();
void tm1637_stop_bit() {
digitalWrite( CLK_PIN, HIGH ); bit_delay();
digitalWrite( DIO_PIN, HIGH ); bit_delay();
int tm1637_send_byte( uint8_t data ) {
uint8_t ack;
for( uint8_t i = 0; i < 8; i++ ) { // Send 8-bit data, LSB first
digitalWrite( DIO_PIN, ( data & 0x01 ) ? HIGH : 0 );
data >>= 1; // shift bit to the right
pinMode( DIO_PIN, INPUT ); // make DIO pin floating (input)
digitalWrite( DIO_PIN, HIGH ); // enable pull-up
ack = digitalRead( DIO_PIN ); // read ACK bit
return (ack==0);
boolean showDigits( uint8_t digits[],
boolean colon=false, uint8_t brightness=7 )
// send the first command
tm1637_start_bit();
tm1637_send_byte( TM1637_CMD1 );
tm1637_stop_bit();
// send the second command
tm1637_start_bit();
tm1637_send_byte( TM1637_CMD2 );
for ( uint8_t i=0, value; i < 4; i++ ) {
value = SEVEN_SEG_DIGITS[ digits[i] ];
if ( (i == 1) && colon ) {
value |= 0x80; // turn on the colon on the display
tm1637_send_byte( value );
tm1637_stop_bit();
// send the third command
tm1637_start_bit();
tm1637_send_byte( TM1637_CMD3 | (brightness & 0x07) | 0x08 );
tm1637_stop_bit();
uint32_t ts;
tm1637_init();
ts = millis();
// show time (hour and minute)
void showTime( uint8_t hh, uint8_t mm, boolean colon=false ) {
static uint8_t data[4];
data[0] = hh/10;
data[1] = hh%10;
data[2] = mm/10;
data[3] = mm%10;
showDigits( data, colon );
void testDigitalWatch() {
static boolean colon=false;
// Start at 12:00:00(hours, minutes and seconds)
static uint8_t hh=12, mm=0, ss=0;
if ( millis() - ts >= 500 ) { // check every 500 msec
showTime( hh, mm, colon );
colon = !colon;
if (colon) {
ss = (ss+1)%60;
if (ss == 0) {
mm = (mm+1)%60;
if (mm == 0) {
hh = (hh+1)%24;
ts += 500;
void testTimer() {
static uint16_t count = 0, temp;
if ( millis() - ts >= 100 ) { // check every 100 msec
temp = count;
count = (count+1) % 10000;
for (uint8_t i=0; i < 4; i++) {
data[3-i] = temp%10;
temp /= 10;
showDigits( data );
ts += 100;
testTimer();
//testDigitalWatch();
