Packeting commands, possible?
Hey!
I'm new to coding!
I was watching this tutorial on 7-segmented LED Display that can show number 0-9.
Tutorial Link
In the picture below he's creating the number zero.
Since the zero will always have that exact same pattern isn't there way to make "packet" for zero?
Can I create a variable say it's called numZERO, so everytime I write numZERO it will be containing that 7-line instead of taking up so much space?
Bare with me friends <3
The information to create any combinations of segments on a 7 segment, will fit into a singe byte. An array of such bytes with 10 elements could hold the information for any of the 10 possible digits and could be accessed by using the number to display as the array index.
For example:
// Bit maps for the seven segment display
const unsigned char Segments[] =
  0b11000000, // 0
  0b11001111, // 1
  0b10100100, // 2
  0b10000110, // 3
  0b10001011, // 4
  0b10010010, // 5
  0b10010000, // 6
  0b11000111, // 7
  0b10000000, // 8
  0b10000011, // 9
// List of digit select lines, least significant digit first
const unsigned char DigitPins[4] = {
  14, 2, 3, 4};  // Anodes (HIGH for on, LOW for off)
const unsigned char SegmentPins[] = {5,6,7,8,9,10,11,12};  // Cathodes (LOW for on, HIGH for off)
  for (int i=0; i<4; i++)
    pinMode(DigitPins[i],OUTPUT);
    digitalWrite(DigitPins[i],LOW);
  for (int i=0; i<8; i++)
    pinMode(SegmentPins[i],OUTPUT);
    digitalWrite(SegmentPins[i],HIGH);
  digitalWrite(12, HIGH);
  digitalWrite(13, HIGH);
  // Get time since last reset
  unsigned long hundredths = millis() / 10;
  unsigned long seconds = hundredths / 100;
  unsigned long minutes = seconds / 60;
  int hours = minutes / 60;
  int clock;
  // Display minutes:seconds up to 100 minutes, then hours/minutes
if (seconds < 100)
    clock = (seconds % 100) * 100 + (hundredths % 100);
if (minutes < 100)
    clock = (minutes % 100) * 100 + (seconds % 60);
    clock = (hours % 100) * 100 + (minutes % 60);
  // Clear all segments before enabling a digit
  for (int s=0; s<8; s++)
    digitalWrite(SegmentPins[s],HIGH);
  // Display each digit, right to left
    // Peel a digit off the low end of the number
    int digit = clock % 10;
    clock /= 10;
    // Blank the MSD if it is zero
    if (i==3 && digit == 0)
      // Display the digit on the seven segments
      unsigned char segments = Segments[digit];
        digitalWrite(SegmentPins[s], segments & 1);
        segments >>= 1;
    if (seconds < 100)
      // Steady decimal point when showing seconds and hundredths
      digitalWrite(13, LOW);
    if (minutes < 100)
      // Steady colon when showing minutes and seconds
      digitalWrite(12, LOW);
      // Make the colon blink each second
      digitalWrite(12, seconds & 1);
      digitalWrite(13, seconds & 1);
    // Turn on the digit briefly
    digitalWrite(DigitPins[i], HIGH);  // Select one digit
    delay(3);
    digitalWrite(DigitPins[i], LOW);
johnwasser:
For example:
  0b11000000, // 0
  0b11001111, // 1
  0b10100100, // 2
  0b10000110, // 3
  0b10001011, // 4
  0b10010010, // 5
  0b10010000, // 6
  0b11000111, // 7
  0b10000000, // 8
  0b10000011, // 9
  int clock;
if (seconds < 100)
if (minutes < 100)
    clock /= 10;
        segments >>= 1;
if (seconds < 100)
    if (minutes < 100)
    delay(3);
@johnwasser so nice of you to have written a code! But I don't really follow. I'm only understanding bits.
At the top, I'm guessing you are explaining what line of code to use for each number.
I have to look up what const unsigned char is.
Is it possible to describe it more specifik, or what could I google for? Don't meant to be rude, thanks again @johnwasser!
hellophant:
'const' means "Don't let the sketch change these values."
'unsigned char' is usually know as 'byte' on the Arduino.
The '[ ]' make it an array of values so you pick which one you want with a index between 0 and 9
