Salut à tous !!!
Sauriez vous m'aiguiller pour la commande de Pins quelconque de l'arduino MEGA à l'aide de l'Arduino Ethernet Shield et d'une page PHP ??
J'avais déjà fais ça avec ce code récupéré sur internet :
//simple button GET server code to control servo and arduino pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//for use with W5100 based ethernet shields
//Powering a servo from the arduino usually DOES NOT WORK.
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 17 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup(){
pinMode(6, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//the pin for the servo co
//enable serial data print
Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
client.println("<link rel='stylesheet' type='text/css' href='http://homeautocss.net84.net/a.css' />");
client.println("<TITLE>Home Automation</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Home Automation</H1>");
client.println("<hr />");
client.println("
client.println("<a href=\"/?lighton\"\">Turn On Light</a>");
client.println("<a href=\"/?lightoff\"\">Turn Off Light</a>
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("?lighton") >0)//checks for on
digitalWrite(6, HIGH); // set pin 4 high
Serial.println("Led On");
else{
if(readString.indexOf("?lightoff") >0)//checks for off
digitalWrite(6, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
Mais la page est franchement dégueulasse.
Mon but serait d'arriver à faire une page de connexion avec Pseudo et Mot de passe pour ensuite avoir accès aux Pins de l'arduino MEGA.
Merci !!
