I have been trying to get the page mode r/w operations to work on my 23lc1024 SRAMs, but I just can't seem to get the syntax correct.
I had first wrote the program similar to how you would write a C program to read and write 32 byte data array, but I found out later that it doesn't actually read the memory as such, and that you had to use certain inbuilt arduino syntax. I would appreciate any help I can get on my following code:
Used the following components:
(1) Arduino Uno
(2) Microchip 23LC51024
ORIGINAL Code by Jim Eli
#include <SPI.h>
//SRAM opcodes
#define RDSR 5
#define WRSR 1
#define READ 3
#define WRITE 2
//i can define these in the setup function below
byte cs_pin[2] = {10, 9};
uint32_t maxpage = 4096;
//Page transfer Functions
//here we can read and write 32 bytes at each address
void Spi23LC1024Read32(uint32_t address, uint8_t cs_pin)//, uint8_t* buffer)
uint32_t i; //important to be local or else the loop in loop function doesnt work
uint8_t read_page;
digitalWrite(cs_pin, LOW); //PORTB &= ~(1<<PORTB2); //set SPI_SS low
SPI.transfer(READ);
SPI.transfer((uint8_t)(address >> 16) & 0xff);
SPI.transfer((uint8_t)(address >> 8) & 0xff); //shift our address 24 bits to the right to make way for each address. if using 23k256 or 23lcv512 microchips you only shift 16.
SPI.transfer((uint8_t)address);
for (i = 0; i < 32; i++)
read_page = SPI.transfer(0x00);
digitalWrite(cs_pin, HIGH); //PORTB |= (1<<PORTB2); //set SPI_SS high
//Serial.println(read_page); //explore this function in more detail
void Spi23LC1024Write32(uint32_t address, uint8_t* buffer170, uint8_t cs_pin)
uint32_t i;
SPI.transfer(WRITE);
SPI.transfer(buffer170*);*
digitalWrite(cs_pin, HIGH); //PORTB |= (1<<PORTB2);*
_/-=-=-=-=-=-=-=-=-=-=-=-=-=-=-==-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-==-/ _
//stream transfer functions.
//here you can read and write as many bytes as you want at each address.
uint32_t i, j, n; //loop iterative values
uint32_t value;
uint32_t num = 0; //for cumulative error counts
//the important 32 element buffer array to be used in page mode
uint8_t buffer170[32] = {170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170, 170};
uint8_t set_value = 170;
void setup(void)
Serial.begin(115200);*
SPI.begin();*
SPI.setClockDivider(SPI_CLOCK_DIV32); //you can play around with different SPI clock times here. Very slow communicating to Serial Monitor when its uncommented*
//Set all pins to high, and then call low when communicating*
pinMode(10, OUTPUT);*
digitalWrite(10, HIGH);*
pinMode(9, OUTPUT);*
digitalWrite(9, HIGH);*
_ /----THIS IS TO READ ALL PAGES IN THE TWO SRAMS ONE AT A TIME----/_
- for (j = 0; j < 2; j++)*
- num = 0;*
- for (i = 0; i < maxpage; i++)*
- Spi23LC1024Write32(i, buffer170, cs_pin[j]);*
- //Serial.println(maxpage); //to check its looped through all 4096 pages*
- Spi23LC1024Read32(i, cs_pin[j]);*
- for (n = 0; n < 32; n++) //because each page consists of a further 32 bytes, here we will check all 32 array elements to see if it matches 170.*
- if (buffer170[n] != set_value)*
- //Serial.print("BITFLIP: ");*
- //Serial.print(value, HEX);*
- //Serial.print(" at: ");*
- //Serial.print(n);*
- //Serial.print(";");*
- //Serial.println(i);*
- num++;*
- Serial.println(num); //How many errors occured in this cs_line/SRAM*
- delay(3000);*
I appreciate this, Thank you
