Paid job: code needed for roulette style game
Hi All,
Im very new to arduino and can already tell im going to get hyper fixated on it and want to learn everything.
The reason im learning is i have a project with a fairly tight deadline that requires a roulette style game as part of it. Ive given this a good go and made some headway into the coding of it but its not quite there yet and with a looming deadline and lots more things to do on this project the anxiety is hitting and im thinking i need to outsource this part and then spend my time learning just how you managed to do it with out the stress of deadline.
The concept is:
The end user would press a momentary switch which would trigger a a roulette style 10 led lighting circuit. Each led would light up in sequence before eventually slowing down untill it stopped on one particular led and that led remained on for 20 seconds.
It would then revert to being off.
When the button is pressed again the same thing would happen but it will stop at a different led.
This would continue like this until it has stopped at every led and then it would just go back to the very start of the whole thing.
Ive got as far as writing the sequence for the chasing led patterns and getting it to stop on various leds and that all works fine. What im having great difficulty is adding the momnetary button part.
If any one can help im happy to pay you for your services
Thanks in advance , Regards Ben
sound strangly simillar to a homework.
Can you describe what kind of difficulty you're having? Random flickering of the signal, no signal, software latch, etc.?
Show this work so the pushbutton can be added.
Put your code in this simulation to test it yourself.
Kindly describe it correctly and briefly to proceed further
