Boas,
Estou com alguma dificuldade em fazer um código para ter um painel led com 3 mensagens, accionadas por um botão.
Consegui visualizar uma mensagem no painel, agora precisava incorporar um botão para aparecer novas mensagens (3 no mínimo).
Agradecia uma ajudinha....
O meu código:
#include <MD_MAX72xx.h>
#include <SPI.h>
#define USE_POT_CONTROL 1
#define PRINT_CALLBACK 0
#define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
#define HARDWARE_TYPE MD_MAX72XX::PAROLA_HW
#define MAX_DEVICES 8
#define CLK_PIN 13 // or SCK
#define DATA_PIN 11 // or MOSI
#define CS_PIN 10 // or SS
// SPI hardware interface
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// Arbitrary pins
//MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// Scrolling parameters
#if USE_POT_CONTROL
#define SPEED_IN A5
#else
#define SCROLL_DELAY 50 // in milliseconds
#endif // USE_POT_CONTROL
#define CHAR_SPACING 1 // pixels between characters
// Global message buffers shared by Serial and Scrolling functions
#define BUF_SIZE 75
char curMessage[BUF_SIZE];
char newMessage[BUF_SIZE];
bool newMessageAvailable = false;
uint16_t scrollDelay; // in milliseconds
void readSerial(void)
static uint8_t putIndex = 0;
while (Serial.available())
newMessage[putIndex] = (char)Serial.read();
if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-3)) // end of message character or full buffer
// put in a message separator and end the string
newMessage[putIndex++] = ' ';
newMessage[putIndex] = '\0';
// restart the index for next filling spree and flag we have a message waiting
putIndex = 0;
newMessageAvailable = true;
else if (newMessage[putIndex] != '\r')
// Just save the next char in next location
putIndex++;
void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col)
// Callback function for data that is being scrolled off the display
#if PRINT_CALLBACK
Serial.print("\n cb ");
Serial.print(dev);
Serial.print(' ');
Serial.print(t);
Serial.print(' ');
Serial.println(col);
#endif
uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
// Callback function for data that is required for scrolling into the display
static char *p = curMessage;
static uint8_t state = 0;
static uint8_t curLen, showLen;
static uint8_t cBuf[8];
uint8_t colData;
// finite state machine to control what we do on the callback
switch(state)
case 0: // Load the next character from the font table
showLen = mx.getChar(*p++, sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
curLen = 0;
state++;
// if we reached end of message, reset the message pointer
if (*p == '\0')
p = curMessage; // reset the pointer to start of message
if (newMessageAvailable) // there is a new message waiting
strcpy(curMessage, newMessage); // copy it in
// !! deliberately fall through to next state to start displaying
case 1: // display the next part of the character
colData = cBuf[curLen++];
if (curLen == showLen)
showLen = CHAR_SPACING;
curLen = 0;
state = 2;
case 2: // display inter-character spacing (blank column)
colData = 0;
state = 0;
curLen++;
default:
state = 0;
return(colData);
void scrollText(void)
static uint32_t prevTime = 0;
// Is it time to scroll the text?
if (millis()-prevTime >= scrollDelay)
mx.transform(MD_MAX72XX::TSR); // scroll along - the callback will load all the data
prevTime = millis(); // starting point for next time
uint16_t getScrollDelay(void)
#if USE_POT_CONTROL
uint16_t t;
t = analogRead(SPEED_IN);
t = map(t, 0, 1023, 25, 250);
return(t);
#else
return(SCROLL_DELAY);
#endif
mx.begin();
mx.setShiftDataInCallback(scrollDataSource);
mx.setShiftDataOutCallback(scrollDataSink);
#if USE_POT_CONTROL
pinMode(SPEED_IN, INPUT);
#else
scrollDelay = SCROLL_DELAY;
#endif
strcpy(curMessage, " ChiPDouro ** Fechado ** ");
newMessage[0] = '\0';
Serial.begin(57600);
Serial.print("\n[MD_MAX72XX Message Display]\nType a message for the scrolling display\nEnd message line with a newline");
scrollDelay = getScrollDelay();
readSerial();
scrollText();
Hello,
I have some difficulty making a code to have a led panel with 3 messages, triggered by a button.
I was able to view a message in the panel, now I needed to incorporate a button to appear new messages (minimum 3).
I would appreciate a little help ....
