Greetings..
Please excuse an old man who has limited social media or forum experience.
I've spent some time going over this forum, and I'm starting this thread.. knowing full well it may be old news. If so, please be so kind as to direct me to previously posted answers so I don't waste too much of your time.
A friend has built a paint sprayer (for spraying small test plates) using a Makeblock XY Plotter and Orion controller board. He put together a simple program using Arduino 1.8.5. I'm including the entire program with this post.
Currently, this program successfully allows him to set up his plotter with a Y-axis "A", "B" or "C" height setting of his choosing, using those particular keys on his keyboard. Once he has chosen his height, he uses his numeric keyboard to move to the left with "4", right with "6", up with "8" and down with "2". This all works perfectly well in the programming example.
He asked if I could come up with a way to use "5" on the keyboard to perform a zig-zag pattern with one keystroke. I used his moveTo and move commands to perform this, but we get no result. The best we get is a quick upward movement on the Y-axis, followed by a long X-axis movement, then a 5-second delay (owing to the 'delay(5000)' command). But no zig-zag. In my attempt, I tried to pause each movement with a 5-second delay so we could watch the progress.. and be sure the plotter arrived at each location with time to spare before implementing another movement. Not working.
If I could please have a working example of a zig-zag pattern and how it might work in this program example, it would be so appreciated.
If this were a simple G-code arrangement, I wouldn't be bothering you with my questions
Thank you in advance! I've been trying to get this going since mid-November off-and-on.
#include "MeOrion.h"
#include <SoftwareSerial.h>
MeStepper stepperx(PORT_2);
MeStepper steppery(PORT_1);
MeLimitSwitch xlimit1(PORT_3,SLOT1);
MeLimitSwitch xlimit2(PORT_3,SLOT2);
MeLimitSwitch ylimit1(PORT_6,SLOT1);
MeLimitSwitch ylimit2(PORT_6,SLOT2);
Serial.println("Spray OS V. 1.xp");
delay(2000);
Serial.println("COM SPEED SET to 9600");
stepperx.setMaxSpeed(1000);
Serial.println("X AXIS INITIALIZING");
stepperx.setAcceleration(20000);
steppery.setMaxSpeed(500);
Serial.println("Y AXIS INITIALIZING");
steppery.setAcceleration(20000);
Serial.println("Activating Spray Control");
pinMode(8, OUTPUT);
digitalWrite(8, 3);
digitalWrite(8, LOW);
Serial.println("Please select from the following");
Serial.println("Enter x to reset X axis");
Serial.println("Enter y to reset Y axis");
Serial.println("Enter a for Height A");
Serial.println("Enter b for Height B");
Serial.println("Enter c for Height C");
Serial.println("Enter 4 to move left");
Serial.println("Enter 6 to move right");
Serial.println("Enter 8 for move UP");
Serial.println("Enter 2 for move DN");
Serial.println("Enter + to spray");
Serial.println("Enter - to stop spray");
Serial.println("Enter 5 for test zig-zag");
if(Serial.available())
char a = Serial.read();
switch(a)
case 'x':
stepperx.moveTo(0);
case 'y':
steppery.moveTo(0);
case 'a':
steppery.moveTo(400);
case 'b':
steppery.moveTo(800);
case 'c':
steppery.moveTo(1200);
case '4':
stepperx.moveTo(2000);
case '8':
steppery.move(200);
case '6':
stepperx.moveTo(0);
case '2':
steppery.move(-200);
case '+':
digitalWrite(8, 3);
case '-':
case '5': <-- this is where my zig-zag routing resides
delay(5000);
steppery.move(200);
delay(5000);
stepperx.moveTo(0);
delay(5000);
delay(5000);
delay(5000);
stepperx.run();
steppery.run();
