pairing 2 bluetooth hc-06 transceiver modules
Quick question,
I couldn't find the answer to this so,
can you pair two hc-06 bluetooth transceivers to each other?
(LINK TO PAGE WHERE I WANT TO BUY THEM)
regards Maarten.
https://alselectro.wordpress.com/2014/10/21/bluetooth-hc05-how-to-pair-two-modules/
You need to use at least one HC-05, and you might as well get two. This is because the HC-06 is slave-only. I think you can get them a lot cheaper on eBay than from that link.
Guess they are slave-only transceivers, but if neither can start the communication, then it's not going to work.
No there isn't.
Being a slave simply means that an HC-06 cannot initiate the connection. That does not mean it is not a transceiver, and goes some way to explain why the HC-05 is a slave by default as well. I imagine about 99% of HC-0x users use their HC-0xs in slave mode and they can all transceive just fine.
I found two HC-05 modules on Gearbest [[/url]
Thanks all for the info I know enough! ](http://www.gearbest.com/other-accessories/pp_227678.html)
$3 looks a lot better. Check the Martyn Currey or Phillipe Cantin websites about Arduino<>Arduino comms with Auto-connect.
HC-06 work great sending data to my cellphone but the phone is the master and the Hc-06 the slave but that works fine for most stuff.
I've now bought two Bluetooth modules from the link. I also found out they were the original sellers and gearbest is just a good seller for arduino stuffs.
I wanted to be able to send data to one Bluetooth module and back and I don't have an iPhone so the phone solution won't work.
I know enough thanks
