hello guys,
my TV only supports RF signals (Sharp aquous) and my remote is fairly broken, i want to build a "middleman" that receives ir signals from my fire tv remote and then send the corresponding RF signal to my TV.
the tv remote itselfs uses a sprf24b31a chip wich is a 2,4ghz rf chip.
i set up a Arduino Nano with an nrf24l01 chip and an IR receiver, but i cant find out wich channel i have to set the nrf24l01 chip to receive the codes from my TV Remote.
is there maybe a way to programm the arduino, so it cycles trough each channel till it receives something from my remote ?
thank you for your help ![]()
edit: i found a datasheet from an Optical mouse wich uses the sprf24b31a chip, maybe i can solder a wire to the right pin and sniff the rf data trough the wired connection?
Edit: and here is a photo of the TV Remote Chip
edit edit: i soldered a wire to the pin 16 of the chip in the wiring diagram and hooked it up to the arduino and printed it out to the serial monitor. its a bunch of 0 and 1 but i can clearly see how it reacts to my presses on the remote. i will try now to hook the wire up to the line in of my soundcard and record each button press.
