# Pairing HC-05 with Android cellphone
**URL:** <https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314>\
**Category:** Networking, Protocols, and Devices\
**Created:** [June 11, 2025, 8:04pm UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314 "2025-06-11T20:04:10Z")\
**Posts on this page:** 11\
**Page:** 1
<div class="post-metadata">
**Author:** ![dianatbp](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/dianatbp/32/1104740_2.png) [@dianatbp](https://forum.arduino.cc/u/dianatbp)\
**Post date:** [June 11, 2025, 8:04pm UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/1 "2025-06-11T20:04:10Z")
</div>
Hi there, I'm having trouble pairing my bluetooth module with an Android cellphone.
It is an Ard-305 bought in Steren, but I understand that it is the same as the HC-05 module.
About I year ago, I paired it with my cellphone, but now I need to pair it with a diferent one. I remember the password and the address, but when I click "search for devices" in my phone's bluetooth settings, it doesn't appear in the list.
I've googled it, but I just find very vague information.
I hope anyone could help me.
**Author:** ![xfpd](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/xfpd/32/1120236_2.png) [@xfpd](https://forum.arduino.cc/u/xfpd)\
**Post date:** [June 11, 2025, 8:37pm UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/2 "2025-06-11T20:37:40Z")
</div>
> [@dianatbp](#):
> HC-05
Turn off the cell phone that is paired. Connect standalone (apply power and ground) open "different" phone bluetooth app, find "available devices"
**Post date:** [June 11, 2025, 11:58pm UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/3 "2025-06-11T23:58:13Z")
</div>
We've already turned off the first phone, and disabled the pair with it, but it didn't work.
And what do you mean with "standalone"? Connect only power and ground? With the arduino? Or with an external source?
**Post date:** [June 12, 2025, 1:03am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/4 "2025-06-12T01:03:58Z")
</div>
> [@dianatbp](#):
> but it didn't work.
What did not work?
> [@dianatbp](#):
Standalone HC-05 is just apply power (and ground) to it. It does not need an external controller to pair
**Post date:** [June 12, 2025, 4:15am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/5 "2025-06-12T04:15:11Z")
</div>
Pairing the Bluetooth device with the other cellphone turned off didn't work.
We tried with a new bluetooth module, and it seems to be working, but now we have trouble because we don't know it's password.
We are trying sending AT commands, but we can't find the right program.
**Post date:** [June 12, 2025, 4:30am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/6 "2025-06-12T04:30:50Z")
</div>
1234 or 0000
**Author:** ![Nick\_Pyner](https://avatars.discourse-cdn.com/v4/letter/n/e8c25b/32.png) [@Nick\_Pyner](https://forum.arduino.cc/u/Nick_Pyner)\
**Post date:** [June 12, 2025, 4:47am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/7 "2025-06-12T04:47:26Z")
</div>
If you really are trying to send AT commands
1. you don't need a password
2. you can create a new password in the same process
3. you cannot communicate by wireless. You need to exit AT mode and start over in comms mode
There must be a bazillion programmes out there for configuring in AT mode. If you cannot find one, you just aren't trying hard enough.
**Post date:** [June 13, 2025, 3:05am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/8 "2025-06-13T03:05:07Z")
</div>
Check the Martyn Currey website.
**Post date:** [June 13, 2025, 4:31am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/9 "2025-06-13T04:31:48Z")
</div>
> [@dianatbp](#):
You vacated that topic a year ago without reporting the results... that you fried the HC05 you were using and now have another bluetooth module.
> [@Problem with module bluetooth HC-05](https://forum.arduino.cc/t/problem-with-module-bluetooth-hc-05/1317247):
> Hi there. I have a problem with my bluetooth module HC-05. I could configure it and paired it to my cellphone (android) correctly using the SoftwareSerial.h library. I'm able to change the name, password, and other parameters with the example code, and it works correctly: #include \<SoftwareSerial.h\> SoftwareSerial bluetooth(10, 11); // RX, TX void setup() { Serial.begin(9600); bluetooth.begin(38400); while (!Serial) { } Serial.println("Configuración"); } void loop() { // run over…
Did you make the voltage divider? Will you post a wiring diagram?
**Post date:** [June 13, 2025, 4:45am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/10 "2025-06-13T04:45:39Z")
</div>
Thank you all for your time and comments. I just tried ressetting the module with the AT commands, and it worked, the pairing was successfull!
**Post date:** [December 10, 2025, 4:45am UTC](https://forum.arduino.cc/t/pairing-hc-05-with-android-cellphone/1388314/11 "2025-12-10T04:45:42Z")
</div>
Closed on December 10, 2025, 4:45am UTC
