Hi all,
I’m using Arduino ethernet board and I have two different bluetooth shields: itead ble shield (http://imall.iteadstudio.com/development-platform/arduino/shields/im130704001.html), and seeed’s Bluetooth shied (http://www.seeedstudio.com/wiki/Bluetooth_Shield).
I cannot figure out how to pair with my macbook/android phone.
With seeed’s blue tooth I upload this code on board (from the official example). On the shield, the led blinks, but neither macbook nor androind can see the board.
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 9
#define TxD 8
#define DEBUG_ENABLED 1
#define PIN_TEMP A5
SoftwareSerial blueToothSerial(RxD,TxD);
int getTemp()
return 44; // fake
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
setupBlueToothConnection();
char recvChar;
while(1)
if(blueToothSerial.available())
{//check if there's any data sent from the remote bluetooth shield
recvChar = blueToothSerial.read();
Serial.print(recvChar);
if(recvChar == 't' || recvChar == 'T')
blueToothSerial.print("temperature: ");
blueToothSerial.println(getTemp());
if(Serial.available())
{//check if there's any data sent from the local serial terminal, you can add the other applications here
recvChar = Serial.read();
blueToothSerial.print(recvChar);
void setupBlueToothConnection()
blueToothSerial.begin(38400); // Set BluetoothBee BaudRate to default baud rate 38400
blueToothSerial.print("\r\n+STWMOD=0\r\n"); // set the bluetooth work in slave mode
blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); // set the bluetooth name as "SeeedBTSlave"
blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
delay(2000); // This delay is required.
blueToothSerial.print("\r\n+INQ=1\r\n"); // make the slave bluetooth inquirable
Serial.println("The slave bluetooth is inquirable!");
blueToothSerial.flush();
So I tried with BLE shield, uploading a blank sketch. Again, shiled’s led blinks but nothing can see it.
Can anyone help me to figure out how it runs?
Thanks in advance
Davide
