Pairing two NRF52832 BLE modules with each other?
Hello,
I just wanted to make sure if you are able to pair two NRF52832 modules with each other(as slave master configuration) and if so how do you access the internal peripherals like the bluetooth and nfc functionality, is there any internal RTC buit in there?
Can the on board ufc antenna be used as a "tag" to be read by other smart devices?
and can you use the NFC antenna both for communication and wireless charging considering the used antenna is capable of it?
Also what is the recommended medium level programming software for it?
