I've got a problem with the PAJ7620 gesture sensor in combination with an Arduino Nano IoT.
The sensor works perfectly when I upload the code to the Arduino, but won't work when I just start the Arduino (plug into power source), without uploading first. Also, when I press the reset button on the Arduino, the sensor works too. I just want it to work, without uploading first or pressing the reset button.
Somebody ran into this problem as well?
Code I used is the demo code from the Seeed library and the demo code from the RevEng_PAJ7620 library. Response is the same...
#include <Wire.h>
#include "paj7620.h"
#define GES_REACTION_TIME 500 // You can adjust the reaction time according to the actual circumstance.
#define GES_ENTRY_TIME 800 // When you want to recognize the Forward/Backward gestures, your gestures' reaction time must less than GES_ENTRY_TIME(0.8s).
#define GES_QUIT_TIME 1000
uint8_t error = 0;
Serial.println("\nPAJ7620U2 TEST DEMO: Recognize 9 gestures.");
error = paj7620Init(); // initialize Paj7620 registers
if (error)
Serial.print("INIT ERROR,CODE:");
Serial.println(error);
Serial.println("INIT OK");
Serial.println("Please input your gestures:\n");
uint8_t data = 0, data1 = 0, error;
error = paj7620ReadReg(0x43, 1, &data); // Read Bank_0_Reg_0x43/0x44 for gesture result.
if (!error)
switch (data) // When different gestures be detected, the variable 'data' will be set to different values by paj7620ReadReg(0x43, 1, &data).
case GES_RIGHT_FLAG:
delay(GES_ENTRY_TIME);
if(data == GES_FORWARD_FLAG)
Serial.println("Forward");
delay(GES_QUIT_TIME);
else if(data == GES_BACKWARD_FLAG)
Serial.println("Backward");
Serial.println("Right");
case GES_LEFT_FLAG:
Serial.println("Left");
case GES_UP_FLAG:
Serial.println("Up");
case GES_DOWN_FLAG:
Serial.println("Down");
case GES_FORWARD_FLAG:
case GES_BACKWARD_FLAG:
case GES_CLOCKWISE_FLAG:
Serial.println("Clockwise");
case GES_COUNT_CLOCKWISE_FLAG:
Serial.println("anti-clockwise");
default:
paj7620ReadReg(0x44, 1, &data1);
if (data1 == GES_WAVE_FLAG)
Serial.println("wave");
delay(100);
Powering as follows:
GND -> GND
VCC -> 3.3V Arduino Nano pin
SDA -> SDA
SCL -> SCL
Strange thing is that everything runs and works when the code is being uploaded, of when I press the reset button on the Arduino, but doesn't run when I normally power the Arduino (tried USB and powerbank).
I tried adding a delay in the setup(), but doesn't fix the problem.
There is also a Neopixel LED Ring wired to the Arduino, which also is wired to GND and 3.3V.
The IR LED in the sensor has a current need for 360ma, plus what ever the other stuff is using. Do you think the 3.3 volt from the Arduino can supply that? Try a separate 3.3 volt supply.
Paul
