i’ve tried to setup a pan tilt servo and a pir alarm. but the servos are interrupted by pir alarm.
is there a way to run both or stop pir after a set time?
i dont remember where but i thought i saw that you could have camera respond to motion area?
this is pan tilt code…
#include <Servo.h>
int ServoHorizontalPin = 3;
int ServoVerticalPin = 4;
int HorizontalPotPin = A0;
int VerticalPotPin = A1;
int ServoH_Min = 50;
int ServoH_Max = 180;
int ServoV_Min = 0;
int ServoV_Max = 180;
Servo HorizontalServo;
Servo VerticalServo;
int HorizontalPotValue;
int HorizontalServoPosition;
int VerticalPotValue;
int VerticalServoPosition;
HorizontalServo.attach(ServoHorizontalPin);
VerticalServo.attach(ServoVerticalPin);
HorizontalPotValue = analogRead(HorizontalPotPin);
VerticalPotValue = analogRead(VerticalPotPin);
HorizontalServoPosition = map(HorizontalPotValue, 0, 1023, ServoH_Min , ServoH_Max);
VerticalServoPosition = map(VerticalPotValue, 0, 1023, ServoV_Min , ServoV_Max);
HorizontalServo.write(HorizontalServoPosition);
VerticalServo.write(VerticalServoPosition);
delay(20);
IMO, you're much better off using microseconds to set servo position than pretending you're setting the position with degrees.
I posted some joystick/servo code here which you might find useful. Reply #23 has links to videos of the code in action.
The code is non-blocking so you should be able to add code to check the PIR sensors. It will take a bit of work to use the sensor data to produce meaningful servo position targets but once you have a target position figured out, the algorithms in the code will move the servos to these targets smoothly.
all i see is "it didnt work" in replies and i dont get how they got it to work. then when i compiled it saved it and i lost my code anyway. changed that setting. thanks anyway. i'll go with sweep,eliminate joystick and try to figure out a manual rest on pir.
