Panel current measurement using acs712 5A
Hello. I've read a lot of blogs on this subject, but there are still points I don't understand. I have a 12v 200mA panel and I want to read how much current this panel draws instantly on the LCD i2c. But I'm experiencing a lot of fluctuation. I would be very happy if you help. Thanks....
Were these instructions also difficult for you?
I will move your topic.
Choose the forum section you use more carefully next time please.
Considering that there is an equivalent of +/-57mA of noise at the output and you are trying to measure only 200mA I can see why.
You need a different sensor
200 mA out of +- 5 A full scale of your sensor is using a small percentage of the sensor's range and will not give you a stable reading. You should think about using a sensor with a lower full scale range.
