Panel Mount Heat Shrink?
Hello,
I am looking for something that is a mix between heat shrink and a grommet, that I could mount to a panel of acrylic and pass wires through.... all of the cables are between 1/4 and 1/8 OD and instead of just drilling holes through the panel, I was looking for something a bit more finished?
I'm going to have a USB cable, a power cable, two RF antennas poking out of the box.... I looked at panel mounts for the power and USB cable, but I think they will take up too much room in my enclosure....
No, I don't think you can combine them in one piece, the material properties are effectively
opposite (heat shrink is below its glass transition temperature, rubber above its glass
transistion temperature). You can get rubber grommets with a strain-relief sleeve built it,
and you could heat shrink over that to bind to the cable.
Use cable glands.
http://www.renewedenergy.com.au/m12-black-nylon-cable-glands-w-locknut-lappkabel?gclid=CNuQqNOIhcYCFU0IvAodEEcAjg
Weedpharma
Some more gland options
http://www.digikey.com/product-search/en/cables-wires-management/cable-and-cord-grips/1704536?k=gland
