Panel mount jack
I’m wanting a panel mount jack for an enclosure, that I can plug a servo into. I’m wondering what type of plugs/jacks would work. I’ve normally used an 1/8" stereo plug, but wondered if there were other options.
Any sort of plug would work, there is a world of choice out there.
Be aware that some plugs cause a short circuit when plugging in/out. This can trigger anything including unwanted effects like damage. -> that makes the world of choice a bit smaller.
robtillaart: Be aware that some plugs cause a short circuit when plugging in/out. This can trigger anything including unwanted effects like damage. -> that makes the world of choice a bit smaller.
Basically - just about any coaxial plug/jack, like the OP's original 1/8" stereo plug/jack; such should be reserved for very low-voltage signals only, where shorts aren't an issue.
For a servo, though - you could do what the RC hobby world does, and just have exposed 3-pin male headers to plug the servos into - fairly standard and expected.
If, however, such connections need more protection from being unplugged, four-pin RJ11 plugs and jacks are a robust and easy-to-use (not to mention common) solution.
Great! I wondered about them, just how much current they can handle. I'm getting a large full rot. servo from SparkFun. I can't find out what current it draws, nor do I know what an RJ11 Jack can handle. But I'd guess half an amp for the servo, and probably an 1amp for the jack?
