Panning A Camera
Hello All you Arduino Pros,
I’m working on a project and am using the Arduino for the first time. I am a total novice at this so please be kind.
My project involves moving a camera 270 degrees back and forth three times every four minutes. I have a servo running back and forth and can stop it for a while between sweeps, however, by using “Delay” I can do nothing else. I’ve looked at Timer.h, SoftTimer, State Machines and AccelStepper to find a way to accomplish my project and am now so confused that I don’t know which way to go. I would really appreciate one of you well experienced folks’ help.
What I want to do is the following:
1 I have a light sensor and would like the program to “check” it every 10 mins looking for a “HIGH”.
2 When a HIGH is detected, I want the servo to sweep 0 to 180 degrees, then 180 to 0 degrees three times EVERY 5 mins.
3 WHILE the servo is sweeping I need a pin to go HIGH (turns on the camera) BUT only while the servo sweeps.
4 Finally, I want this to go on until the light sensor returns a LOW.
I have tried some different things using “servo.h” with no success, would one or more of you please suggest a Library and some code that will accomplish my goal???
I would really appreciate any help I can get.
This is the Programming forum, where you are expected to post your code. If you need Project Guidance, you should have gone there.
Look at the "blink without delay" example code for ideas. Also you should post your code if you want help with it.
OK,
I did look at the Blink with out delay and I have tried the following sketch:
/* This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// set pin numbers:
const int ldrPin =  2;      // the number of the LDR pin
const int lsrPin =  6;      // the number of the LIGHT pin
Servo myservo;  // create servo object to control a servo
// Variables will change:
int ldrState = LOW;             // ledState used to set the LDR
long previousMillis = 0;        // will store last time LDR was updated
int pos = 0;    // variable to store the servo position
long interval = (4 * 60 * 60 * 1000);           // interval at which to run servo (milliseconds)
  // set the digital pin as output/input:
  pinMode(ldrPin,INPUT);
  pinMode(lsrPin,OUTPUT);
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LDR is HIGH it is in the dark & program should run:
    if (ldrState == HIGH)
    digitalWrite(lsrPin, HIGH);
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                                     // in steps of 1 degree
    myservo.write(pos);                    // tell servo to go to position in variable 'pos'
    delay(60);                                   // servo speed
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
    digitalWrite(lsrPin, LOW);
Help?
delay(60);
This is supposed to be "without delay", but you've got several.
Well, good for you.
Help?
Sure thing. With what?
