Panning a Ping Sensor
I wanted my robot to have a ping sensor that moves from left to right.
The pseudo code would be:
check for obtacles in front
if there is nothing near in front move forward
if there is something near in front, then stop.
after stopping turn the ping left and listen for obstacles then turn the ping right and listen
return the ping to center
If the left value was larger than right, turn right
if the right value was larger than left, turn left
if the right value equals the left value, reverse
repeat this over and over again
well this is what i want it to do.
the code i have now (works great for turning one direction) is:
#include <Servo.h>
Servo ServoLeft;
Servo ServoRight;
int ledPin1 = 1;
int ledPin3 = 3;
unsigned long echo = 0;
int ultraSoundSignal = 7; // Ultrasound signal pin
unsigned long ultrasoundValue = 0;
 ServoLeft.attach(8);
 ServoRight.attach(9);
 pinMode(ledPin1, OUTPUT);
  pinMode(ledPin3, OUTPUT);
pinMode(ultraSoundSignal,OUTPUT);
unsigned long ping(){
pinMode(ultraSoundSignal, OUTPUT); // Switch signalpin to output
digitalWrite(ultraSoundSignal, LOW); // Send low pulse
delayMicroseconds(2); // Wait for 2 microseconds
digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
delayMicroseconds(5); // Wait for 5 microseconds
digitalWrite(ultraSoundSignal, LOW); // Holdoff
pinMode(ultraSoundSignal, INPUT); // Switch signalpin to input
digitalWrite(ultraSoundSignal, HIGH); // Turn on pullup resistor
 echo = pulseIn(ultraSoundSignal, HIGH); //Listen for echo
 ultrasoundValue = (echo / 58.138) * .39; //convert to CM then to inches
return ultrasoundValue;
void straight() {
  ServoLeft.write(0); //0 is bak
  ServoRight.write(180); //180 is bak
  void turnRight() // turn right function
    {ServoLeft.write(0); //0 is bak
  ServoRight.write(0); //180 is bak
  void avoideWalls()
    if(ultrasoundValue < 18)                            // if the distance is less than ___
        digitalWrite(ledPin3, HIGH);
        digitalWrite(ledPin1,LOW);
    turnRight();                            // turns Walbot right using turnRight function
    delay(100);
   else                                      // otherwise
             digitalWrite(ledPin3, LOW);
               digitalWrite(ledPin1, HIGH);
    straight();                            // go straight using the straight function
 ping();
  avoideWalls();
  delay(20);
So can someone help me with making that happen? :smiley:
The avoideWalls function makes use of the one value set by ping. The ping function fires the sensor in one position, and waits for a response.
The ping function needs to either set three values (left, front, right), moving the sensor between readings, or it needs to be called three times, moving the sensor between calls, and saving the value (ultrasoundValue) into three variables (leftValue, frontValue, rightValue).
Then, avoideWalls needs to decide what to do based on those three values.
@Paul S
would you be able to give me a peak at what that would look like in code? :smiley:
And yeah i want the ping to pan left, stop, scan, pan center, stop scan, pan right, stop scan, return to center and determine which direction was furthest.
I'm having a lot of trouble with this. :[
You've got code to move a servo, although the code you posted does not say anything about the servo that moves the sensor.
You've got code to fire the sensor and get a value.
Moving the servo to a position shouldn't be a problem. Firing the sensor shouldn't be a problem. Putting the result in an array shouldn't be a problem.
The only problem that remains is determining which of three values is largest. That really shouldn't be a problem.
