Paper Thin Switch
For my project, I need a paper thin switch with cables attached which are also preferably paper thin. Regular Tactile Button switches are too big for my purpose.
Does such a thing exist?
Have you looked at SMD parts?
The 4mm pad spaced SMD tactile switch here is pretty thin.
Otherwise, maybe a force sensitive resistor pad - look at sparkfun.com
force sensitive resistor pad is exactly the size and shape I am looking for but can I get a simple switch instead in same shape/size?
What I am trying to achieve is to have the user touch/hold on to the switch/pad to complete the circuit. I have approx 3Volts in circuits.
How thick can it be?
You are looking for a membrane press button, usually they are custom made, but you might be lucky if you Gargle.
They are only good for low voltage/current switching
Tom.... :slight_smile:
kashif_izhar:
Why not use that then?
Paper is about 0.1mm to 0.15mm thick, BTW
These membrane switches, 0.8mm thick, are available from several eBay suppliers:
http://www.ebay.com/itm/DC-1-Key-Matrix-Membrane-Switch-Control-Keypad-Keyboard-Panel-Super-Slim-ON-OFF-/390861800675
kashif_izhar:
Consider having a touch switch, for example by using:
http://playground.arduino.cc/Main/CapacitiveSensor?from=Main.CapSense
or a dedicated IC such as:
Thanks for pointing in the right direction. Membrane switch seem to be the solution.
Use a MPR121
