Parallax LCD Countdown Timer
Hi! I really new to Arduino and I don’t know how to go about this school project :fearful: : I need to display a countdown clock on my Parallax Serial LCD screen. I’ve gotten as far as being able to write to the LCD screen, but I don’t know how to structure the timer. Here is what I’ve got so far: Thanks for your help!
const int TxPin = 6;
#include <SoftwareSerial.h>
SoftwareSerial mySerial = SoftwareSerial(255, TxPin);
pinMode(TxPin, OUTPUT);
digitalWrite(TxPin, HIGH);
mySerial.begin(9600);
delay(100);
mySerial.write(12); // Clear
mySerial.write(17); // Turn backlight on
delay(5); // Required delay
mySerial.print(“BEGIN TEST”); // First line
delay(1000); // Wait 1 second
Simplest clock based upon what you posted (I added symbolic defines for some magic numbers)
#define CLEAR 12
#define BACKLIGHTON 17
  delay(100);
  mySerial.write(CLEAR );
  mySerial.write(BACKLIGHTON );
  mySerial.print("BEGIN TEST");   // First line
  unsigned long now = millis(); // internal clock since startup
  int hours = 0;
  int minutes = 0;
  int seconds = 0;
  mySerial.write(CLEAR);
  MySerial.print(now);
But that clock is displaying in milliseconds, now your turn to make hours, minutes and seconds of it.
thanks! I’ve made a little progress but i’m still not there yet:
#define CLEAR 12
  delay(100);
  float hours,minutes,seconds;
  //int hours = 0;
  //int minutes = 0;
  //int seconds = 0;
  mySerial.print(hours,now/3600000);
  mySerial.write("h ");
  mySerial.print(minutes,now/60000);
  mySerial.write("m ");
  mySerial.print(seconds,now/1000);
  mySerial.write("s ");
it displays “0h 0m 0s” but doesn’t quite act how i’d like it to. I was hoping that dividing the uptime by 1000, it would give me the number of seconds elasped, but instead it just endlessly prints 0’s. any thoughts?
you must separate the math from the displaying part,
think how you would convert 6000 seconds in hours and minutes and seconds with pen/paper
next step in code
  unsigned long ts = now/1000;  // convert milliseconds to (temporary) seconds
  int hours = ts /3600;  // calculate the whole hours in ts
  ts = ts - hours * 3600;  // subtract the hours from ts leaving minutes and seconds
  // fill in the right formulas for minutes and seconds and correct the variable ts if needed
  int minutes = ...
  ts = ...
  int seconds = ...
  ts = ...
  mySerial.print(hours);
  mySerial.print("h ");
  mySerial.print(minutes);
  mySerial.print("m ");
  mySerial.print(seconds);
  mySerial.print("s ");
write - writes only one byte
print - writes a string or a number (under the hood it calls write for every char or digit)
Awesome!! It now displays the time as ‘xh xm xs’… however the time starts at 1m 6s? it doesn’t take that long to start up… This is what I have so far:
#define CLEAR 12
  delay(100);
  //float hours, minutes, seconds;
  int hours = ts /3600;            // calculate the hours in ts
  int minutes = ts /60;            // calculate the minutes in ts
  ts = ts - minutes * 60;          // subtract the minutes from ts leaving seconds
  int seconds = ts;
  ts = ts - seconds * 1;
now let it run for a while and think about how to prefix a leading zero if needed...
I figured out a way to make the time start at 0h 0m 0s, but it displays the millis on the next line. which is not ideal. I also put an alarm that goes off after 30 minutes, which is what i need for my project, but I wonder if there is a way to make it count down from 30 minutes instead though?
#define CLEAR 12
  delay(100);
  int seconds = ts /1;
  delay(5);
  mySerial.write(148);               //carraige return
  mySerial.print(now);               //display current millis, otherwise the time starts at 1m6s?!
  if(minutes == 30)
  mySerial.write(220);
  mySerial.write("BOOM");
Where do you want it displayed?
Does this carriage return push millis (actually "now") to the next line? Is this what you consider to be not ideal?
To do this, can you figure out the starting time, add 30 minutes and then subtract the current time from the starting time? You'll have to change your "Boom" criterion.
