I have a 16x2 Parallax Serial LCD, I was wondering if anyone has been able to get it work?
It has 3 pins: GND, 5V and RX. I have TX going to pin 1 (TX) on my Diecimila, and am running the following code:
int ledPin = 13; // IR LED connected to digital pin 13
int statusPin = 12; // LED connected to digital pin 12
volatile byte rpmcount;
volatile int status;
unsigned int rpm;
unsigned long timeold;
void rpm_fun()
//Each rotation, this interrupt function is run twice, so take that into consideration for
//calculating RPM
//Update count
rpmcount++;
//Toggle status LED
if (status == LOW) {
status = HIGH;
status = LOW;
digitalWrite(statusPin, status);
//Interrupt 0 is digital pin 2, so that is where the IR detector is connected
//Triggers on FALLING (change from HIGH to LOW)
attachInterrupt(0, rpm_fun, FALLING);
//Turn on IR LED
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
//Use statusPin to flash along with interrupts
// pinMode(statusPin, OUTPUT);
rpmcount = 0;
rpm = 0;
timeold = 0;
status = LOW;
//Update RPM every second
//Don't process interrupts during calculations
detachInterrupt(0);
rpm = rpmcount;
timeold = millis();
rpmcount = 0;
//Write it out to serial port
// Serial.println(12,BYTE);
Serial.println(rpm,DEC);
//Restart the interrupt processing
