parallax ping sensor and firmata
I was able to send distance data pretty easily to Pure Data via the SimpleMessageSystem. All that simplicity went out the window when switching to OF and Firmata on the arduino.
I need to send distance data to OF. The below code gets me a value of -1 but I need an int sent back to OF.
One of my problems is that I am confused by sending and receiving Analog or Digital data. The Ping sensor plugs into digital pin #7. But since the inches are computed as an int, should I send back to OF as analog?
here is my code:
#include <Firmata.h>
byte digitalPin;
char firstChar;
char secondChar;
int pingPin = 7;
    Firmata.begin(57600);
   while(Firmata.available()) {
      Firmata.processInput();
   //Firmata.sendDigitalPort(pingPin, computeDistance());
   Firmata.sendAnalog(pingPin, computeDistance());
long computeDistance(){
 long duration, inches, cm;
   // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // We give a short LOW pulse beforehand to ensure a clean HIGH pulse.
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  return microsecondsToInches(duration);
  //cm = microsecondsToCentimeters(duration);
long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
thanks for your help!
got it with Firmata.sendAnalog(); on the arduino and arduino.getAnalog(); on the OF side...
