Parallax RFID Reader Code
Can someone tell me how I can get a tag read only once? When a tag is scanned it is being printed two or three times on the serial monitor. I also would like to have a time limit after a tag is scanned before the reader will detect it again. Is this possible?
int val = 0;
int bytesread = 0;
char tag[11];    // holds the tag and a terminating
#define enable 2
#define start_byte 0x0A
#define stop_byte 0x0D
//**************Programmed Tag ID's******************************
char ID[11] = {'0','C', '0', '0', '5', '1', '5', '4', '9', 'A'};
  Serial.begin(2400);
  pinMode(enable,OUTPUT);
  digitalWrite(enable, LOW);
  enableRFID();
  getRFIDTag();
  printCode();
  disableRFID();
  //printCode();
// functions/
void enableRFID()
void disableRFID()
  digitalWrite(enable, HIGH);
void getRFIDTag()
 if(Serial.available() > 0)
   if((val = Serial.read()) == 10)
      bytesread = 0;
      while(bytesread < 10)
          val = Serial.read();
          if((val == start_byte) || (val == stop_byte))
          tag[bytesread] = val;
          bytesread++;
void printCode()
  if(Serial.read() == stop_byte)
    if(strcmp(tag, ID) == 0)
      Serial.print("The tag is: ");
      Serial.println(tag);
      Serial.print("Invalid Tag");
Once you have printed the tag, clear the array. getRFIDTag() returns if there is no new tag data to read.
      static unsigned long lastReceivedTime = 0;
      // Require five seconds minimum between activations
      if (millis() - lastReceivedTime > 5000) {
    lastReceivedTime = millis();
I am trying to setup a interrupt timer that will be set for 5 minutes for my RFID tags. I want each RFID tag to have to wait 5 minutes before it can be reactivated once it was already scanned. Can someone tell me how I can do this? As of right now, I have two tags programmed. I have attempted to code this but am lost on what I need to do next. Any help would be appreciated!
int  val = 0;
int weight = 0;
char code[11];
int bytesread = 0;
volatile int counter = 0;
///TESTING
int LEDRed = 12;
int LEDYellow = 11;
int LEDGreen = 10;
#define enable 2
char tag[11] = {'0','C', '0', '0', '5', '1', '5', '4', '9', 'A'};
char tag1[11] = { '0', 'C', '0', '0', '5', '1', 'E', 'D', '1', '4'};
  Serial.begin(2400);
  pinMode(enable, OUTPUT);
  enableRFID();
  //TESTING
  pinMode(LEDRed, OUTPUT);
  pinMode(LEDYellow, OUTPUT);
  pinMode(LEDGreen, OUTPUT);
  getRFIDTag();
  printTag();
void ISR_timer() {
  counter++;
//RFID Functions
void enableRFID()
  digitalWrite(enable,LOW);
void disable()
  digitalWrite(enable,HIGH);
void getRFIDTag()
    if((val = Serial.read()) == 0x0A)  //10
    {   // check for header
      bytesread = 0;
      while(bytesread<10)
        if( Serial.available() > 0)
          if((val == 0x0A)||(val == 0x0D))
          code[bytesread] = val;
          bytesread++;
void printTag()
      if(bytesread == 10)
       if (strcmp(code, tag) == 0)
        weight = 10;
        Serial.print("Steven tag is: ");
        Serial.println(code);
        //digitalWrite (LEDGreen, HIGH);
        Serial.println(weight);
        dog_weight();
      else if (strcmp(code, tag1) == 0)
        weight = 70;
        Serial.print("The Second tag is: ");
        dog_weight();
         Serial.print("INVALID: ");
         bytesread = 0;
         disable();
           delay(1500);
           enableRFID();
 void dog_weight()
   if (weight <= 20)
      delay(2000);
      digitalWrite (LEDGreen, LOW);
   else if (weight >= 60)
      digitalWrite (LEDYellow, HIGH);
      delay(2000);
     digitalWrite (LEDYellow, LOW);
     digitalWrite (LEDRed, HIGH);
     delay(2000);
     digitalWrite (LEDRed, LOW);
How would YOU tell someone who tried to scan their tag within 5 minutes to take a hike? Hint: It does NOT involve interrupts.
Once you know how YOU would do it, translating that into code will be nearly trivial.
I've just merged your two cross-posts for you. Please don't cross-post.
