Parallel Bus replaced with 74HC595
Hi folks,
I've just got my LCD with LC7981 Chipset all setup and running but now I need some more free pins on the AVR/Arduino.
Just until now, I connected every data and control pin from the display to the AVR. Now I'm trying to replace the 8 datalines (DB0-DB7) with one 74HC595 shift register.
This is my original code, which works pretty well:
// Puts data onto the data pins
void DG16080::data(unsigned int data) {
  digitalWrite(_DB0, bitRead(data, 0));
  digitalWrite(_DB1, bitRead(data, 1));
  digitalWrite(_DB2, bitRead(data, 2));
  digitalWrite(_DB3, bitRead(data, 3));
  digitalWrite(_DB4, bitRead(data, 4));
  digitalWrite(_DB5, bitRead(data, 5));
  digitalWrite(_DB6, bitRead(data, 6));
  digitalWrite(_DB7, bitRead(data, 7));
When replacing this routine with this one:
  digitalWrite(_LATCH, LOW);
  shiftOut(_DATA, _CLOCK, LSBFIRST, data);
  digitalWrite(_LATCH, HIGH);
I'm in trouble. From your point of view, are these codes comparable or is the 595-variant (2nd code block) trash?
I've already tested output of the 595-variant with different values and it seems this code is working well.
I connected DB0 to Q0, DB1 to Q1 and so on.
Please let me know your thoughts.
Thanks in advance
It looks OK to me.
I don't quite get the question. You are saying your second code block works, but not in the context of being used in place of the first code block?
One possible problem - the second version might be slightly faster. Try adding a small delay.
