I have 2 older ham radios that I bought computer interfaces for. The ports are similar to a parallel port, in fact I once had a Visual Basic windows app that I wrote, that communicated with them through the computers' parallel port, but it wrote to the port directly setting/reading each bit and some control lines.
In total, to control the radios the connections are:
8 data lines
1 Read Pulse
1 Write Pulse
1 SRQ line (Service Request line that shows data is being transferred to/from the radio)
1 Data Valid line that shows data has been received
1 Send line, which will put the radio into transmit mode
1 Squelch line, goes high when a signal is received
1 Ground
So there's 15 data lines I need to read/control each radio, and I have 2 radios, so I would need 30 i/o data lines.
I currently have a UNO board I bought back in 2015. It's an old board, but hopefully it'll do what I need.
What add-ons should I get to be able to control this many i/o lines?
I believe they make serial to parallel port adapters, but not sure if they would work for this, plus I would need 2 of them to accommodate the number of i/o.
Looking at my stash that I bought, I found 3 Nano DCCDuinos, which appear to have 16 digital i/o lines. Would that work? Still going over documentation on it.
The boards/radios do not need to communicate with each other.
I'm trying to digest how the DCCDuino actually physically works. It looks like these can be standalone or work with my UNO?
I would like to have 1 USB cable going to the arduino, and 2 cables coming out to each of the radios... just to cut down on the usb requirements
Or..
if one USB per radio works, that might be fine as well.
OK both those are complete Arduino systems, either is suitable. Some opinions vary (!) as to which is better…
I use the UNO mostly, because that’s what I have handiest.
Dupont wires of variously gendered ends make lashing up either board with many of the modules you can get easy, I bought a bunch of every kind, so same argument for the not UNO board, just different gender cabling.
Often when if I actually finish or nearly finish the software on the UNO I move that code to one of the many other boards available based on the mechanical constraints.
HTH and sry if you already knew or figured that all out.
