I have an RC car with the following components:
- Arduino Uno
- 2 DC motors (1 for drive motor and one steering motor)
- L293D H Bridge
- 3 Ultrasonic sensors (HC SR04; front, side, rear)
- 9V Battery
and I want to perform a parallel parking sequence with the following concept:
- Car is moving forward at a constant velocity parallel to any potential parking spaces
- While the car is moving, the ultrasonic sensor on the side is constantly measuring for depth
- Once the ultrasonic sensor detects a depth > lets say 10 cm, the car will recognize that there is a potential parking space, however, it needs to be long enough for the car to fit
- At this point, a timer starts while the car moves forward with a constant velocity
- While the depth > 10 cm for 4 seconds (arbitrary time but the idea is velocity x time = distance so if it’s the car is travelling at 0.1 m/s for 4 seconds, the distance is 0.4 m or 40 cm.
- This 40 cm is longer than the car, and there is space to park, therefore, start the parallel parking sequence
- a. Turn all the way to the right
b. Drive motor in reverse for half a second (or whatever value)
c. Wheels all way to left
etc…
My problem is, while the millis() function is running, I want to make a copy of the time as soon as the the ultrasonic sensor detects a depth. The timer will continues as long as the depth > 10 cm.
The timer will stop as soon as the depth < 10 cm and reset that timer to 0
if the time is > whatever time I decide when I do the calculations, then start parallel parking.
I’m not sure exactly how to manipulate the timer function so it saves multiple instances of time
If someone can help me with the concept, I can definitely code it myself and will ask for feedback as necessary
Thank you so much and ask me anything if it is unclear
