Parallel programmer on IDE 1.0
Hello friends I want to build the parallel programmer to be able to program my arduino using the ICSP on a breadboard.When using this programmer or this method does the atmega need to have the cristal oscilator connected or I just need a minimum setup,vcc and the ICSP pins?
HugoPT: I want to build the parallel programmer to be able to program my arduino using the ICSP on a breadboard.
Why not a serial programmer?
Only if the fuses on the target (the processor being programmed) are set so the target needs a crystal to run.
If the fuses on target are set so the target runs from the internal oscillator then you can use a minimum setup.
Thanks it really clarify my doubt.
