parameter as Stream type
I would write a generic code for my device which listen the instructions from from Serial (USB) and Ethernet (web).
I saw theses classes extend the Stream.h.
Can I do something like:
void parseLine(Stream *inputStream);
Then an error occurs while a call:
Foo::parseLine(_client);
_client is type of EthernetClient
error: cannot convert 'EthernetClient' to 'Stream*' for argument '1' to 'void Core::readUint8(Stream*, uint8_t&)'
Can you help me?
Thx :slight_smile:
Yes, you can.
Not surprising. You defined the function taking a pointer, but you aren't calling it with a pointer.
Try:
Foo::parseLine(&_client);
Wünderbar!!! Great thanks, it works.
:slight_smile:
Damned!
The skelton function compiles.
But when I write something inside I have a problem.
void readUint8(Stream *inputStream, uint8_t &out)
    int c;
    while ((c=inputStream.read())/*!=-1*/ && '0'<=c && 'c'<='9') {
      out = (out *10) + ((uint8_t) (c -'0'));
error: request for member 'read' in 'inputStream', which is of non-class type 'Stream*'
I include <Stream.h> in my .h…
Well read() is "virtual" in Stream.h but it is called in Stream.cpp
I.E:
int Stream::peekNextDigit()
  int c;
  while (1) {
    c = timedPeek();
    if (c < 0) return c;  // timeout
    if (c == '-') return c;
    if (c >= '0' && c <= '9') return c;
    read();  // discard non-numeric
This code works.
Why I can't use "inputStream.read()"?
:confused:
I add a '*':
while ((c=(*inputStream).read())
It compiles but I don't know why.
A simpler way exists to do that?
Foo::test(Stream **p) {
p.read();
Foo::test(&&Serial)?
The pointer deference operator is ->, not .
while ((c=inputStream->read())
Ok, thx!
