Parllax RFID reader with Leonardo HEX!
So I can view the string but can not use the string with any operators like match string and use it:
while(rfid.available()>0)
c=rfid.read();
msg += c;
Serial.println(msg);
Serial.println(msg.length());
if(msg.length()>=10) // this number is low to get the correct string size to print... any bigger the string has extra bits
digitalWrite (RedLED,LOW); //Test for now to see if string came in, always works!
//rfid.println(msg);
if(msg == "BDECF6F696569696965695E5EB00" || msg == "BDECF6F6965616B6F5DD95E5EB00") // either card does not work! but if i make it <= that works... but not what I need!
rfid.println(msg);
//digitalWrite (GreenLED,LOW);
msg="";
else {rfid.println(msg);msg="";} // the will print out the serial port the in coming string and I will receive: [BD][EC][F6][F6][96][56][96][96][96][56][95][E5][EB][00] and looks correct 90% of the time???
I have also tried the longer code with memcmp operator and that would not even print back what was stored as a byte or print out "code" as a long enuff string to match the card number...
Help!
I suspect that you are including some framing character in your string. The Parallax reader I have sends ten decimal digits followed by CR and LF (0x13 and 0x10).
// PARALLAX RFID VCC     to Arduino 5V
// PARALLAX RFID /ENABLE to Arduino D2
// PARALLAX RFID SOUT    to Arduino D3
// PARALLAX RFID GND     to Arduino Gnd
// Modified by Worapoht K.
#include <SoftwareSerial.h>
#define enablePin 2
#define rxPin 3
#define txPin 4
SoftwareSerial RFID = SoftwareSerial(rxPin, txPin);
#define START_CHAR 10
#define END_CHAR 13
  Serial.begin(9600);  // Hardware serial for Monitor 2400bps
  RFID.begin(2400);    // RFID reader SOUT at 2400bps
  pinMode(enablePin,OUTPUT);       // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(enablePin, LOW);    // Activate the RFID reader
  int bytesread, val;
  String code = "";
  // Wait for header byte
  while(RFID.read() != START_CHAR)
    /* DO NOTHING */    ;
  bytesread = 0;
  while ((val = RFID.read()) != END_CHAR)
    if (val == START_CHAR)
      break; // Bad frame
    bytesread++;
    if (bytesread > 10)
      break;  // Too many characters
    code += val;     // append the character
  digitalWrite(enablePin, HIGH);    // Deactivate the RFID reader
  if (bytesread == 10)  // Valid read.  10 characters + END_CHAR
  {  // if 10 digit read is complete
    if (code == "48524953696548555648")
      Serial.println("That's the round tag.");
      if (code == "48704851485249505067")
        Serial.println("That's the rectangular tag.");
        Serial.print("Unrecognized code: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
  delay(1000);                       // wait for a second
