Parola_Scrollling_ESP8266 Create WiFiAP itself
Hi, i cant get this code to works.. id try to tweak Parola_Scrolling_ESP8266 library example that connected to any Wifi Network that been put inside code to should make it own Wifi Hotspot (AP mode?)
Tehre is no error message regarding this code.. there is Wifi Signal, there is IP adress if you connected to it... but cant view the website.
by the way im using Wemos D1 R2 Board
// Use the Parola library to scroll text on the display
// Demonstrates receiving and displaying text received from a web interface.
// User can enter text through a web browser and this will display as a
// scrolling message on the display. Some parameters for the text can also
// be controlled from the web page.
// IP address for the ESP8266 is displayed on the scrolling display
// after startup initialization and connection to the WiFi network.
// Connections for ESP8266 hardware SPI are:
// Vcc       3v3     LED matrices seem to work at 3.3V
// GND       GND     GND
// DIN        D7     HSPID or HMOSI
// CS or LD   D8     HSPICS or HCS
// CLK        D5     CLK or HCLK
// MD_MAX72XX library can be found at https://github.com/MajicDesigns/MD_MAX72XX
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// Turn on debug statements to the serial output
#define  DEBUG  0
#if  DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers are for ESO8266 hardware SPI and will probably not
// work with your hardware and may need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 8
#define CLK_PIN   D5 // or SCK
#define DATA_PIN  D7 // or MOSI
#define CS_PIN    D8 // or SS
// HARDWARE SPI
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// WiFi login parameters - network name and password
//const char* ssid = "CABot";
//const char* password = "HelloCoVid";
#ifndef APSSID
#define APSSID "ESPap"
#define APPSK  "thereisnospoon"
#endif
/* Set these to your desired credentials. */
const char *ssid = APSSID;
const char *password = APPSK;
// WiFi Server object and parameters
//WiFiServer server(80);
ESP8266WebServer server(80);
// Scrolling parameters
uint8_t frameDelay = 25;  // default frame delay value
textEffect_t	scrollEffect = PA_SCROLL_LEFT;
// Global message buffers shared by Wifi and Scrolling functions
#define BUF_SIZE  512
char curMessage[BUF_SIZE];
char newMessage[BUF_SIZE];
bool newMessageAvailable = false;
const char WebResponse[] = "HTTP/1.1 200 OK\nContent-Type: text/html\n\n";
const char WebPage[] =
"<!DOCTYPE html>" \
"<html>" \
"<head>" \
"<title>MajicDesigns Test Page</title>" \
"<script>" \
"strLine = \"\";" \
"function SendData()" \
"  nocache = \"/&nocache=\" + Math.random() * 1000000;" \
"  var request = new XMLHttpRequest();" \
"  strLine = \"&MSG=\" + document.getElementById(\"data_form\").Message.value;" \
"  strLine = strLine + \"/&SD=\" + document.getElementById(\"data_form\").ScrollType.value;" \
"  strLine = strLine + \"/&I=\" + document.getElementById(\"data_form\").Invert.value;" \
"  strLine = strLine + \"/&SP=\" + document.getElementById(\"data_form\").Speed.value;" \
"  request.open(\"GET\", strLine + nocache, false);" \
"  request.send(null);" \
"</script>" \
"</head>" \
"<body>" \
"<p><b>MD_Parola set message</b></p>" \
"<form id=\"data_form\" name=\"frmText\">" \
"<label>Message:<br><input type=\"text\" name=\"Message\" maxlength=\"255\"></label>" \
"<br><br>" \
"<input type = \"radio\" name = \"Invert\" value = \"0\" checked> Normal" \
"<input type = \"radio\" name = \"Invert\" value = \"1\"> Inverse" \
"<br>" \
"<input type = \"radio\" name = \"ScrollType\" value = \"L\" checked> Left Scroll" \
"<input type = \"radio\" name = \"ScrollType\" value = \"R\"> Right Scroll" \
"<br><br>" \
"<label>Speed:<br>Fast<input type=\"range\" name=\"Speed\"min=\"10\" max=\"200\">Slow"\
"<br>" \
"</form>" \
"<br>" \
"<input type=\"submit\" value=\"Send Data\" onclick=\"SendData()\">" \
"</body>" \
"</html>";
//const char *err2Str(wl_status_t code)
//  switch (code)
//  case WL_IDLE_STATUS:    return("IDLE");           break; // WiFi is in process of changing between statuses
//  case WL_NO_SSID_AVAIL:  return("NO_SSID_AVAIL");  break; // case configured SSID cannot be reached
//  case WL_CONNECTED:      return("CONNECTED");      break; // successful connection is established
//  case WL_CONNECT_FAILED: return("CONNECT_FAILED"); break; // password is incorrect
//  case WL_DISCONNECTED:   return("CONNECT_FAILED"); break; // module is not configured in station mode
//  default: return("??");
uint8_t htoi(char c)
  c = toupper(c);
  if ((c >= '0') && (c <= '9')) return(c - '0');
  if ((c >= 'A') && (c <= 'F')) return(c - 'A' + 0xa);
  return(0);
void getData(char *szMesg, uint16_t len)
// Message may contain data for:
// New text (/&MSG=)
// Scroll direction (/&SD=)
// Invert (/&I=)
// Speed (/&SP=)
  char *pStart, *pEnd;      // pointer to start and end of text
  // check text message
  pStart = strstr(szMesg, "/&MSG=");
  if (pStart != NULL)
    char *psz = newMessage;
    pStart += 6;  // skip to start of data
    pEnd = strstr(pStart, "/&");
    if (pEnd != NULL)
      while (pStart != pEnd)
        if ((*pStart == '%') && isdigit(*(pStart + 1)))
          // replace %xx hex code with the ASCII character
          char c = 0;
          pStart++;
          c += (htoi(*pStart++) << 4);
          c += htoi(*pStart++);
          *psz++ = c;
          *psz++ = *pStart++;
      *psz = '\0'; // terminate the string
      newMessageAvailable = (strlen(newMessage) != 0);
      PRINT("\nNew Msg: ", newMessage);
  // check scroll direction
  pStart = strstr(szMesg, "/&SD=");
  if (pStart != NULL)
    pStart += 5;  // skip to start of data
    PRINT("\nScroll direction: ", *pStart);
    scrollEffect = (*pStart == 'R' ? PA_SCROLL_RIGHT : PA_SCROLL_LEFT);
    P.setTextEffect(scrollEffect, scrollEffect);
    P.displayReset();
  // check invert
  pStart = strstr(szMesg, "/&I=");
  if (pStart != NULL)
    pStart += 4;  // skip to start of data
    PRINT("\nInvert mode: ", *pStart);
    P.setInvert(*pStart == '1');
  // check speed
  pStart = strstr(szMesg, "/&SP=");
  if (pStart != NULL)
    int16_t speed = atoi(pStart);
    PRINT("\nSpeed: ", P.getSpeed());
    P.setSpeed(speed);
    frameDelay = speed;
void handleWiFi(void)
  static enum { S_IDLE, S_WAIT_CONN, S_READ, S_EXTRACT, S_RESPONSE, S_DISCONN } state = S_IDLE;
  static char szBuf[1024];
  static uint16_t idxBuf = 0;
  static WiFiClient client;
  static uint32_t timeStart;
  switch (state)
  case S_IDLE:   // initialise
    PRINTS("\nS_IDLE");
    idxBuf = 0;
    state = S_WAIT_CONN;
  case S_WAIT_CONN:   // waiting for connection
//    client = server.available();
    if (!client) break;
    if (!client.connected()) break;
#if DEBUG
    char szTxt[20];
    sprintf(szTxt, "%03d:%03d:%03d:%03d", client.remoteIP()[0], client.remoteIP()[1], client.remoteIP()[2], client.remoteIP()[3]);
    PRINT("\nNew client @ ", szTxt);
#endif
    timeStart = millis();
    state = S_READ;
  case S_READ: // get the first line of data
    PRINTS("\nS_READ ");
    while (client.available())
      char c = client.read();
      if ((c == '\r') || (c == '\n'))
        szBuf[idxBuf] = '\0';
        client.flush();
        PRINT("\nRecv: ", szBuf);
        state = S_EXTRACT;
        szBuf[idxBuf++] = (char)c;
    if (millis() - timeStart > 1000)
      PRINTS("\nWait timeout");
      state = S_DISCONN;
  case S_EXTRACT: // extract data
    PRINTS("\nS_EXTRACT");
    // Extract the string from the message if there is one
    getData(szBuf, BUF_SIZE);
    state = S_RESPONSE;
  case S_RESPONSE: // send the response to the client
    PRINTS("\nS_RESPONSE");
    // Return the response to the client (web page)
    client.print(WebResponse);
    client.print(WebPage);
    state = S_DISCONN;
  case S_DISCONN: // disconnect client
    PRINTS("\nS_DISCONN");
    client.flush();
    client.stop();
    state = S_IDLE;
  default:  state = S_IDLE;
void handleRoot() {
  //server.send(200, "text/html", "<h1>You are connected</h1>");
  Serial.begin(57600);
  PRINTS("\n[MD_Parola WiFi Message Display]\nType a message for the scrolling display from your internet browser");
  P.begin();
  P.displayClear();
  P.displaySuspend(false);
  P.displayScroll(curMessage, PA_LEFT, scrollEffect, frameDelay);
  curMessage[0] = newMessage[0] = '\0';
  // Connect to and initialise WiFi network
//  PRINT("\nConnecting to ", ssid);
//  WiFi.begin(ssid, password);
//  while (WiFi.status() != WL_CONNECTED)
//    PRINT("\n", err2Str(WiFi.status()));
//    delay(500);
//  PRINTS("\nWiFi connected");
  // Start the server
  server.begin();
  PRINTS("\nServer started");
  /* You can remove the password parameter if you want the AP to be open. */
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.on("/", handleWiFi);
  server.begin();
  Serial.println("HTTP server started");
  // Set up first message as the IP address
  sprintf(curMessage, "%03d:%03d:%03d:%03d", WiFi.softAPIP()[0], WiFi.softAPIP()[1], WiFi.softAPIP()[2], WiFi.softAPIP()[3]);
  PRINT("\nAssigned IP ", curMessage);
  handleWiFi();
//  server.handleClient();
  if (P.displayAnimate())
    if (newMessageAvailable)
      strcpy(curMessage, newMessage);
    P.displayReset();
