Parse a serial string
i am kind of new to arduino.
I have a program sending a serial string $ABDATA,xx,yy. and i want the x and the y in two int numbers. but Serial.parseInt() will not work because of there is letters in the string? and i have tryed a lot of other different methodes but cant find one that will work for me. xx is a position from 0 to 255 and yy is a speed from 0 to 1000 $ABDATA is contant and is not importent.
Thanks alot \Yakov
Hello and welcome :slight_smile:
The easiest way is to use sscanf
The homework hotline is currently closed. You need to post some code.
I understand it can be hard for beginners… This example will read everything available in the Serial buffer until a “\r” is found, and then will try to parse as you described:
  // if there is something in the serial buffer
  if ( Serial.available() > 0 )
    static char input[64];
    static uint8_t i;
    // read one character
    char c = Serial.read();
    // if the character is not a "\r" and the input buffer is not full
    if ( c != '\r' && i < 64-1)
      // store the character at the end of the input buffer
      input[i++] = c;
    // else, the input is ready to be processed
      // add a null terminator to make it a valid C string
      input[i] = '\0';
      //reset index for the next serial message
      i = 0;
      // try parsing the input as you described
      uint8_t xx;
      uint16_t yy;
      if ( sscanf( input, "$ABDATA,%hhu,%hu", &xx, &yy ) == 2 )
        Serial.println( xx );
        Serial.println( yy );
