Parse data
I want to parse an HTTP Get response I receive on the serial port.
Following is a sample response I receive
<?xml version='1.0' encoding='UTF-8'?><feed xmlns='http://www.w3.org/2005/Atom' xmlns:openSearch='http://a9.com/-/spec/opensearchrss/1.0/' xmlns:gs='http://schemas.google.com/spreadsheets/2006' xmlns:batch='http://schemas.google.com/gdata/batch'><id>https://spreadsheets.google.com/feeds/cells/0ApZSAfRKvUfDdElxdmRLZ1FqSEVKejVJTjRoZmRvVEE/od6/public/basic</id><updated>2013-09-22T09:15:09.974Z</updated><category scheme='http://schemas.google.com/spreadsheets/2006' term='http://schemas.google.com/spreadsheets/2006#cell'/><title type='text'>Form Responses</title><link rel='alternate' type='text/html' href='https://spreadsheets.google.com/pub?key=0ApZSAfRKvUfDdElxdmRLZ1FqSEVKejVJTjRoZmRvVEE'/><link rel='http://schemas.google.com/g/2005#feed' type='application/atom+xml' href='https://spreadsheets.google.com/feeds/cells/0ApZSAfRKvUfDdElxdmRLZ1FqSEVKejVJTjRoZmRvVEE/od6/public/basic'/><link rel='http://schemas.google.com/g/2005#batch' type='application/atom+xml' href='https://spreadsheets.google.com/feeds/cells/0ApZSAfRKvUfDdElxdmRLZ1FqSEVKejVJTjRoZmRvVEE/od6/public/basic/batch'/><link rel='self' type='application/atom+xml' href='https://spreadsheets.google.com/feeds/cells/0ApZSAfRKvUfDdElxdmRLZ1FqSEVKejVJTjRoZmRvVEE/od6/public/basic?range=d10'/><author><name>igor.kovba</name><email>igor.kovba@gmail.com</email></author><openSearch:totalResults>1</openSearch:totalResults><openSearch:startIndex>1</openSearch:startIndex><entry><id>https://spreadsheets.google.com/feeds/cells/0ApZvAfRKvUfDdElxdmRLZ1FqSEVKejVJTjRoZmRvVEE/od6/public/basic/R10C4</id><updated>2013-09-22T09:15:09.974Z</updated><category scheme='http://schemas.google.com/spreadsheets/2006' term='http://schemas.google.com/spreadsheets/2006#cell'/><title type='text'>D10</title><content type='text'>456</content><link rel='self' type='application/atom+xml' href='https://spreadsheets.google.com/feeds/cells/0ApZSAfRKvUfDdElxdmRLZ1FqSEVKejVJTjRoZmRvVEE/od6/public/basic/R10C4'/></entry></feed>
I want to read the value in D10 i.e. parse
type='text'>D10456
so that I am able to read the value 456 in the cell D10. Please help me with a code to parse the data
To parse xml files it's usually better to consider the '>' and '/n' as the end of line, so you don't need a larger buffer, since each xml file line are usually very big.
I use something similar to get some weather information. Here is an ideia.
void weather() {
  byte idx = 0;
  char character;
  int timeout = 0;
  char icon[12] = {};
  char response[64] = {};
  if (tcp.connect("site", TCP_PORT) == 1) {
    while (tcp.connected()) {
      while (tcp.available()) {
        timeout = 0;
        character = tcp.read();
        if (idx < sizeof(response) - 1) {
          response[idx++] = character;
        if (character == '\n' || character == '>') {
          if (strstr(response, "temperature") && strstr(response, "value")) {
            sscanf(strstr(response, "value"), "value=\"%hhd\"", &temp);
            //process
            tcp.stop();
        memset(response, 0, sizeof(response));
        idx = 0;
      if (timeout++ >= 1000) {
        tcp.stop();
      delay(1);
  tcp.stop();
Could you get the spreadsheet to output the data in CSV format which would be easier to parse?
...R
Can you please help me with your example for the code I have posted. Especially the functions strstr,sscanf and memset. How do I use them in a program for arduino?
Arank:
void weather() {
byte idx = 0;
  char character;
  int timeout = 0;
  char icon[12] = {};
        timeout = 0;
            sscanf(strstr(response, "value"), "value="%hhd"", &temp);
            //process
            tcp.stop();
        idx = 0;
        tcp.stop();
      delay(1);
  tcp.stop();
Is the stuff before the number you are interested in ALWAYS D10
...R
Yes the data will be present between 'text'> and where the value 456 is present in the given example. The HTTP reply will remain same always , however the data can change and can be either of integer or float( signed or unsigned) datatype.
I think you could then use the function strcspn() to find the start of the standard preceding text and find the number by counting forward from that position.
...R
Hi, I am using the web client example for arduino to obtain data from a xml source.
The HTTP response is obtained in the variable char c. I am trying to convert the characters obtained in the response to a string using the variable char a[] using the code given below. But I am unable to do so. Please help if something is wrong with the following piece of code.
 if(client.available()) {
    char c = client.read();
    a[i]=c;
    i=i+1;
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    i=0;
    client.stop();
// Serial.println(i);
    // do nothing forevermore:
    while (true);
One character at a time.
But, we can't see how a is defined. I'll assume "incorrectly".
What proof do you have to support that statement?
@ PaulS
1)Yes, response is one char at a time.
komalhm:
variable char a[]
as mentioned in my previous post.
3)The serial monitor does not show any data. When a[] and i are commented it displays the characters.
But there is no code to prove that you have sized the array correctly.
I stand by my assertion that "incorrectly" is how you have defined the array a.
