Below is some code I use to get GET request and parce out the desired info.
//zoomkat 5-24-10
// http://www.arduino.cc/en/Tutorial/TextString for WString.h
#include
#include
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
Server server(84); //server port
String readString = String(100); //string for fetching data from address
String teststring = String(100);
String finalstring = String(100);
String flag = String(2);
int ind1 = 0;
int ind2 = 0;
int pos = 0;
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//enable serial data print
Serial.begin(9600); }
void loop(){
// Create a client connection
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString.append(c);
//if HTTP request has ended
if (c == '\n') {
//Serial.println(readString);
//readString looks like "GET /?-0p1555-1p500t1000 HTTP/1.1"
if(readString.contains("-")) { //test for servo control sring
readString.replace('-', '#');
pos = readString.length(); //capture string length
//find start of servo command string (#)
ind1 = readString.indexOf('#');
//capture front part of command string
teststring = readString.substring(ind1, pos);
//locate the end of the command string
ind2 = teststring.indexOf(' ');
//capturing the servo command string from readString
finalstring = readString.substring(ind1, ind2+ind1);
//print "finalstring" to com port;
Serial.println(finalstring); //print string with CR
//GET /?Slidervalue0=1800&Submit=Sub+0 HTTP/1.1
if(readString.contains("Slidervalue")) {
ind1 = readString.indexOf('u');
ind2 = readString.indexOf('&');
finalstring = readString.substring(ind1+1, ind2);
finalstring.replace('e', '#');
finalstring.replace('=', 'p');
//now output HTML data header
client.println("HTTP/1.1 204 Zoomkat");
client.println();
client.println();
delay(1);
//stopping client
client.stop();
//clearing string for next read
readString="";
teststring="";
finalstring="";
