Parse integer from serial data if recieved
Having a bit of trouble parsing the information I have received over a bluetooth connection, when a integer is between the values of 7 & 29 I wish to store this information and use it later on in my code however when I print out int x over serial it does not display the number I sent over bluetooth only the number 0. Any help?
int ledPin = 13;
int x;
String readString;
String str;
  pinMode(ledPin, OUTPUT);
  Serial.println("Starting Up!");
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "GET:")     //When "GET" is received over serial, turn led light on. - WORKS.
      digitalWrite(ledPin, HIGH);
    if (str = Serial.readStringUntil ('\n'));
      x = Serial.parseInt();
      digitalWrite(ledPin, LOW);
      Serial.println(x);
    readString="";
Please edit your message to put the code in code tags, not quote tags.
Why do you need to piss away resources on the String class to get such a small number of characters?
    delay(3);
Stupid as a box of rocks. That is NOT the way to "assure that there is data to read"!
Why is this an if statement?
You clearly haven't a clue about reading serial data. You need to dump all that code and start here: https://forum.arduino.cc/index.php?topic=288234.0
Managed to read around and complete what I wanted to do and PaulS don't worry I didn't waste the resources on the string class once I figured out the correct and most efficient way to do it.
